VPN Security
saquib.tandel
router acting as VPN-Server and NAT is working great, looking at attach config do I require additional steps to secure the box.
crypto isakmp policy 10
authentication pre-share
crypto isakmp key Key111 address 196.88.1.10
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
set peer 196.88.1.10
set transform-set myset
match address 101
interface Ethernet0/0
ip address 172.17.1.1 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Ethernet1/0
ip address 100.1.1.1 255.255.255.0
ip nat outside
crypto map myvpn
router ospf 1
log-adjacency-changes
network 172.17.1.1 0.0.0.0 area 0
ip classless
ip route 0.0.0.0 0.0.0.0 100.1.1.254
ip http server
no ip http secure-server
ip nat inside source list 175 interface Ethernet1/0 overload
access-list 101 permit ip 172.17.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 175 deny   ip 172.17.1.0 0.0.0.255 10.1.1.0 0.0.0.255
access-list 175 permit ip 172.17.1.0 0.0.0.255 any
6 Replies 6
Calin C.
Level 5
Level 5
I'm not a big fan of "ip http server" and if you have remote access to this box (telnet, ssh) I would recommend an ACL to limit the addresses which can access it. With ACL you also eliminate an DoS attack that can target your remote service ports (23 or 22).
Calin
Thank you for useful links.
Can you help with links for these scenario
  1. Locking VPN router with security parameter ( Router is dedicated for site - to- siteVPN )
  2. Locking Router with security parameter for Remote_Access_VPN
  3. Placing ASA before VPN router ; encryption on ASA and tunnel on router
VPN_Router------------ASA------------Internet_Router=============INTERNET
In regards to your question 1 and 2, you can use either CBAC or ZBFW to lock the VPN router.
With your question 3, I suppose you mean GRE tunnel is terminated on the router, and ASA firewall terminated the LAN-to-LAN IPSec tunnel.
If that is what you are looking for, here is a sample configuration (GRE tunnel terminated on router, and LAN-to-LAN IPSec terminated on the firewall):
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800a43f6.shtml
The sample configuration is on PIX firewall, however, the concept is the same. Majority of the commands are the same, with slight changes with ASA firewall with the tunnel-group configuration for the pre-shared key. Here is a sample LAN-to-LAN configuration on ASA for your reference:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080950890.shtml
Hope that helps.
Thanks for replying.
P#3 scenario
(Site_A) VPN_Router------------ASA------------Internet_Router=============INTERNET=================VPN_RTR (SiteB)
On site_A, GRE Tunnel is on VPN _Router and ipsec on ASA   ( I was looking for this scenario sample config )
Don't exactly have the sample config for just GRE tunnel on 1 router with ASA terminating the IPSec tunnel, and GRE over IPSec on the other router, but this is the sample configuration that you can use where the router is configured just for GRE tunnel, and PIX is configured to terminate the IPSec:
And here is the config for your router that terminates GRE over IPSec:
http://www.cisco.com/en/US/tech/tk827/tk369/technologies_configuration_example09186a00800946b8.shtml
Combination of the 3 sample configurations above will achieve what you would like to configure.
Hope that helps.
