Bookmark
Subscribe
1173
VPN site-to-site (Amazon Web Services) : NAT Exempt
Kirov11
Dear Everyone,
Cisco Firepower Extensible Operating System (FX-OS) v2.12.0 (build 499)
Cisco Firepower 2130 Threat Defense v7.2.4 (build 165)
Model : Cisco Firepower 2130 Threat Defense (77) Version 7.2.4 (Build 165)
I need help configuring an IPsec VPN between my network and the AWS site-to-site. As shown in the attached photo, the connection protocol IKEv2 IPsecOverNatT is enabled, and both ends agree on this protocol. Initially, there are no problems with the connection, and I can ping and access the EC2 instances at the AWS remote site.
However, the problem arises when I notice that the connection between this remote site becomes intermittent, with ping requests timing out every 30 seconds. This is unacceptable. I also have VPN connections set up as site-to-site, using a different protocol, IKEv1.
I suspect that this could be due to a NATting issue since my protocol is using IPsecOverNatT, which shouldn't have NAT enabled.
My question is, how do I configure NAT exemption for this? It's worth noting that I have other VPN connections set up as site-to-site using a different protocol, IKEv1, and they are also using the same ISP line. Additionally, I have several existing NAT rules. I've attached a screenshot of the NAT rules, with the highlighted rule being for AWS NATting.
  1. gnet_aws: 10.16.0.13 - This is the private IP for the remote site.
  2. gnet_lmt_to_aws: 172.21.0.0/16 - This is the internal private IP range.
It's important to mention that the AWS documentation states that the MAIN SA Selector should be CIDR 0.0.0.0, else it will encounter a problem with TS_UNACCEPTABLE during Phase 2 rekeying. I have managed to solve this issue, but I am now facing problems with NAT exemption.
Again, how do I configure NAT exemption for this? The CIDR is too broad, and the existing rule might cause conflicts. Also, how do I add an exemption? Should I specify only the remote side address (EC2 Private IP) in another group object?
Options: A. Should I create another group object and specify only the remote side address (EC2 Private IP)?
Let me know if you need more information. Your help is greatly appreciated
Kirov11
Hi Everyone,
Issue has been solved by matching the Child SA between side.
Thank you for the support.
6 Replies 6
can you share the
packet-tracer for traffic from LAN to LAN
share it here
MHM
Hi @MHM Cisco World  Thank you for reply here is Internal IP to Remote Site.
> packet-tracer input vlan20-fwmgt tcp (172.21.11.26) (1024) 10.17.0.159 www detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Elapsed time: 29855 ns
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0x559c8dc2d0, priority=1, domain=permit, deny=false
hits=14255095, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0100.0000.0000
input_ifc=vlan20-fwmgt, output_ifc=any
Phase: 2
Type: UN-NAT
Subtype: static
Result: ALLOW
Elapsed time: 20472 ns
Config:
nat (TM_DOME1,any) source static gnet_aws gnet_aws destination static gnet_lmt_to_aws gnet_lmt_to_aws no-proxy-arp
NAT divert to egress interface TM_DOME1(vrfid:0)
Untranslate 10.17.0.159/80 to 10.17.0.159/80
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Elapsed time: 9894 ns
Config:
access-group CSM_FW_ACL_ global
access-list CSM_FW_ACL_ advanced permit ipinip any any rule-id 268444685
access-list CSM_FW_ACL_ remark rule-id 268444685: PREFILTER POLICY: No Prefilter
access-list CSM_FW_ACL_ remark rule-id 268444685: RULE: DEFAULT TUNNEL ACTION RULE
This packet will be sent to snort for additional processing where a verdict will be reached
in id=0x55a4d7ee10, priority=12, domain=permit, deny=false
hits=179600, user_data=0x5579de1800, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
src ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=vlan20-fwmgt(vrfid:0)
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, ifc=TM_DOME1(vrfid:0), vlan=0, dscp=0x0, nsg_id=none
input_ifc=any, output_ifc=any
Phase: 4
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class_map_traceroute
match access-list traceroute
policy-map global_policy
class class_map_traceroute
set connection decrement-ttl
service-policy global_policy global
in id=0x559e9524d0, priority=7, domain=conn-set, deny=false
hits=952432, user_data=0x55a39812f0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
dst ip/id=0.0.0.0, mask=0.0.0.0, port=0, tag=any, dscp=0x0, nsg_id=none
input_ifc=vlan20-fwmgt(vrfid:0), output_ifc=any
Phase: 5
Type: NAT
Subtype:
Result: ALLOW
Config:
Static translate 172.21.11.26/1024 to 172.21.11.26/1024
in id=0x559c4775b0, priority=6, domain=nat, deny=false
hits=141945, user_data=0x559e915e40, cs_id=0x0, flags=0x0, protocol=0
src ip/id=172.21.0.0, mask=255.255.0.0, port=0, tag=any
dst ip/id=10.16.0.0, mask=255.248.0.0, port=0, tag=any, dscp=0x0, nsg_id=none
input_ifc=any, output_ifc=TM_DOME1(vrfid:0)
Phase: 6
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
in id=0x558ff99220, priority=0, domain=nat-per-session, deny=false
hits=37992418, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x559c3cb100, priority=0, domain=inspect-ip-options, deny=true
hits=1361909, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: FOVER
Subtype: standby-update
Result: ALLOW
Elapsed time: 43503 ns
Config:
in id=0x55a3cdf6e0, priority=20, domain=lu, deny=false
hits=291315, user_data=0x0, cs_id=0x0, flags=0x0, protocol=6
Phase: 9
Type: VPN
Subtype: encrypt
Result: ALLOW
Elapsed time: 13648 ns
Config:
out id=0x559c153c30, priority=70, domain=encrypt, deny=false
hits=3787, user_data=0x123ff7d4, cs_id=0x559bff4ef0, reverse, flags=0x0, protocol=0
input_ifc=any(vrfid:65535), output_ifc=TM_DOME1
Phase: 10
Type: NAT
Subtype: rpf-check
Result: ALLOW
Elapsed time: 5118 ns
Config:
out id=0x559ecce310, priority=6, domain=nat-reverse, deny=false
hits=124788, user_data=0x559ef51bc0, cs_id=0x0, use_real_addr, flags=0x0, protocol=0
Phase: 11
Type: VPN
Subtype: ipsec-tunnel-flow
Result: ALLOW
Elapsed time: 49474 ns
Config:
Reverse Flow based lookup yields rule:
in id=0x55a59e01e0, priority=70, domain=ipsec-tunnel-flow, deny=false
hits=3787, user_data=0x12401e2c, cs_id=0x559bff4ef0, reverse, flags=0x0, protocol=0
src ip/id=10.16.0.0, mask=255.248.0.0, port=0, tag=any
dst ip/id=172.21.0.0, mask=255.255.0.0, port=0, tag=any, dscp=0x0, nsg_id=none
input_ifc=TM_DOME1(vrfid:0), output_ifc=any
Phase: 12
Type: NAT
Result: ALLOW
Elapsed time: 4265 ns
Config:
hits=37992420, user_data=0x0, cs_id=0x0, reverse, use_real_addr, flags=0x0, protocol=6
Phase: 13
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Elapsed time: 1706 ns
Config:
in id=0x559617b120, priority=0, domain=inspect-ip-options, deny=true
hits=824938, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Elapsed time: 93830 ns
Config:
New flow created with id 47385277, packet dispatched to next module
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_tcp_normalizer
snp_fp_snort
snp_fp_translate
snp_fp_adjacency
snp_fp_encrypt
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Module information for reverse flow ...
snp_fp_ipsec_tunnel_flow
snp_fp_translate
snp_fp_snort
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Phase: 15
Type: EXTERNAL-INSPECT
Subtype:
Result: ALLOW
Elapsed time: 26443 ns
Config:
Application: 'SNORT Inspect'
Phase: 16
Type: SNORT
Subtype: appid
Result: ALLOW
Elapsed time: 14824 ns
Config:
service: (0), client: (0), payload: (0), misc: (0)
Phase: 17
Type: SNORT
Subtype: firewall
Result: ALLOW
Elapsed time: 180260 ns
Config:
Network 0, Inspection 0, Detection 2, Rule ID 268459029
Starting rule matching, zone 1 -> 11, geo 0 -> 0, vlan 0, src sgt: 0, src sgt type: unknown, dst sgt: 0, dst sgt type: unknown, user 9999999, no url or host, no xff
Matched rule ids 268459029 - Allow
Result:
input-interface: vlan20-fwmgt(vrfid:0)
input-status: up
input-line-status: up
output-interface: TM_DOME1(vrfid:0)
output-status: up
output-line-status: up
Action: allow
Time Taken: 532868 ns
Hi friend
Sorry for late reply I search look for your post in security vpn, until I found it here in routing.
Anyway
This nat with any as egress interface is suboptimal, change it and specify correct interface.
Also I don't see lookup did you config routing for remote Lan (AWS prefix)?
You're right that the 'ANY' rout should be specified. Yes, I've added the AWS prefix 10.16.0.0/13. There are two possible changes I need to make: following AWS's recommendation to use the CIDR 0.0.0.0/0 and removing the manually added static route for the AWS VPN
stupid question maybe, but other than the ping timouts, does the VPN actually experience user traffic problems as well ?
Either way, on the Cisco, I think the command:
no crypto ikev2 ipsec-over-nat-t
disables the NatT.
Kirov11
Hi Everyone,
