vpn tunnel site to site always disconnect
amralrazzaz
Level 5
Level 5
hi all
my network:  ISP --- ASA5516---ISR 2911 router --- 2960 switch ---2960 switch
i have ASA5516-FTD-K9 and im using site to site vpn ikev2 (ipsec) , the tunnel always going down after several days untili change an option then it back up again then after some days it back down again so i have to back this option to its 1st status so tunnel goes up again and so on
- im using 2 public ip one for vpn tunnel and other for nat (internet for users)
- im using nat exempt but im not sure if this is correct or not ?
i dunt know if i keep using nat exemption or should remove ?  and why tunnel goes down until i change nat exempt to back up and then after some days it goes down so i have to back this option to same status again and so on ...  please check attached pic
amr alrazzaz
0 Replies 0
