- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-26-2021
12:46 PM
- last edited on
10-01-2023
10:59 PM
by
Translator
Hello Folks!
I'm replacing my router from ISR 4431 to ASR 920 and the
netflow
is not working, actually there are other commands as well.
Netflow
when I try to apply the config into the interface shows the following msg:
RT01(config-if)# ip flow monitor FLOWin input
% Flow Monitor: Failed to add monitor to interface: Unsupported template
I saw documentation that I should change my license to "metroaggrservices", but this license is not available.
I'm running the image: asr920-universalk9_npe.16.09.03.SPA.bin
Is there any other way to enable the
Netflow
The command below are not supported as well, do you know the alternative?
platform qfp utilization monitor load 80
platform hardware throughput level 1000000
Solved! Go to Solution.
- Labels:
Other Routing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-26-2021 02:29 PM
what kind of license you have :
check below thread :
https://community.cisco.com/t5/network-management/flexible-netflow-asr920-trouble/td-p/3767918
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-26-2021 02:29 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-27-2021
05:05 PM
- last edited on
10-01-2023
11:01 PM
by
Translator
I saw this documentation that you mentioned, but I did this process and didn´t work".
BR238-INT-RTR02#sh license
Index 1 Feature: advancedmetroipaccess
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Count: Non-Counted
License Priority: Medium
Index 2 Feature: metroipaccess
Period left: Not Activated
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
Index 3 Feature: metroaccess
Index 4 Feature: 1588
Index 5 Feature: 1GEupgradelicense
Index 6 Feature: 10GEupgradelicense
Index 7 Feature: 12portGE-2port10GE
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2021
02:25 AM
- last edited on
10-01-2023
11:02 PM
by
Translator
RT01(config-if)# ip flow monitor FLOWin input % Flow Monitor: Failed to add monitor to interface: Unsupported template
Can you post
Netflow
related all the config and what interface you trying to configure?
here is the sample config :
low record TEST_IPV4_RECORD
match ipv4 source address
match ipv4 destination address
match ipv4 protocol
match transport source-port
match transport destination-port
collect counter packets
collect counter bytes
flow exporter TEST_EXPORTER
destination 192.168.100.1
source Loopback1
transport udp 9999
flow monitor TEST_IPV4_MONITOR
cache timeout inactive 20
cache timeout active 180
interface GigabitEthernet0/1/0
ip address 10.10.10.2 255.255.255.0
ip flow monitor TEST_IPV4_MONITOR input
speed 1000
no negotiation auto
check the SDM prefer template :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-28-2021 08:52 AM
what is the exact 920 model you have ? According to the documentation linked below, the following applies:
--> For Cisco ASR-920-12CZ-A, ASR-920-12CZ-D, ASR-920-4SZ-A, ASR-920-4SZ-D, and ASR-920-12SZ-IM routers—sdm prefer netflow-video.
--> RSP2 and Cisco ASR-920-24SZ-IM, ASR-920-24SZ-M, ASR-920-24TZ-M routers—sdm prefer video.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-29-2021
03:16 AM
- last edited on
10-01-2023
11:14 PM
by
Translator
Hello Georg!
It is working now, for some reason I had to apply the command
2x, and only in the second time that worked.
I appreciate you and Balaji.Bandi for supports me.
