VPN WITH MULTICAST
lidium.net
Hello everyone I have an ipsec VPN created, but in addition to this we need to let me do multicast between points of the VPN, for a system VideoConference someone can guide me how to do it?
Thanks for your help
Router 1 connected to source
version 12.4
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname xxx
no logging buffered
no aaa new-model
crypto isakmp policy 10
hash md5
authentication pre-share
crypto isakmp key XXXX address 195.x.x.70
crypto ipsec transform-set setmenorca esp-des esp-md5-hmac
crypto map palma 10 ipsec-isakmp
set peer 195.XX.XX.70
set transform-set setmenorca
match address 100
ip cef
no ip domain lookup
ip multicast-routing
username admin privilege 15 password 7 XXXXXXXXXXXXXX
interface Ethernet0
ip address 192.168.3.251 255.255.255.0
ip nat inside
ip virtual-reassembly
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache cef
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
ip address 217.XXX.XXX.188 255.255.255.192
ip nat outside
no ip route-cache
no snmp trap link-status
crypto map palma
pvc 8/32
encapsulation aal5snap
ip route 0.0.0.0 0.0.0.0 ATM0.1
no ip http server
no ip http secure-server
ip nat inside source route-map nonat interface ATM0.1 overload
access-list 100 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 deny ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 192.168.3.0 0.0.0.255 any
snmp-server community private RO
snmp-server enable traps tty
route-map nonat permit 10
match ip address 120
paolo bevilacqua
IPsec cannot carry multicast.
Please configure a GRE tunnel between routers doing the VPN and apply "tunnel protection" command on it.
The tunnel will be then encrypted and able to carry multicast.
