VRF and redistribute connected command.
tinhnho123
Level 2
Level 2
Hi guys,
I currently have a router that doing EIGRP, below is its EIGRP:
router eigrp Prod
address-family ipv4 unicast autonomous-system 150
 topology base
   redistribute static
 exit-af-topology
  network 10.10.10.0
exit-address-family
Because I don't want new route leak into current EIGRP Prod above, I just configured a new interface and put it in a VRF (before the router didn't any VRF):
vrf definition External
  address-family ipv4
  exit-address-family
  address-family ipv6
  exit-address-family
Interface g0/0/0
 vrf fowarding External
 ip address 172.16.16.1 255.255.255.250
 no shutdown
Would this command 'redistribute connected' which under EIGRP Prod above advertise my newly 172.16.16.1/30 into EIGRP Prod even though I have this interface g0/0/0 in a VRF?
Thanks.
7 Replies 7
NO you need route leaking between VRF and global RIB otherwise the prefix will not redistrubte
MHM
Thanks. Just for my learning:
If I don't have a VRF configured for my new interface g0/0/0, would this 'redistribute connected' command in EIGRP Prod advertise my prefix 172.16.16.0/20 into it?
Does EIGRP have command to do route leaking between VRF?
If I don't have a VRF configured for my new interface g0/0/0, would this 'redistribute connected' command in EIGRP Prod advertise my prefix 172.16.16.0/20 into it? Yes
Does EIGRP have command to do route leaking between VRF? NO you need bgp for leaking
MHM
Hello
You need to add that interface into its own address VRF AS
Example::
router eigrp Prod
address-family ipv4 unicast vrf External autonomous-system 150
af-interface g0/0/0
network 172.16.16.1 0.0.0.0
Kind Regards
Paul
Hi Paul, i dont want to advertise this prefix into existing EIGRP Prod.
Thanks.
Hello
So what do you want to do with it, either way its in it own vrf so the other eigrp routes in the eigrp process wont be able to reach it just other hosts in the same vrf will be able to either dynamically via eigrp or statically.
Kind Regards
Paul
is this issue solved ?
MHM
