VRF Aware EtherChannel
s.nasheet
I am trying to confiure Layer 3 port channel between 6006  and cisco 4503 switch.
Existing connection between them is a layer 3 link with IP address and VRF configured.
Can I move the VRF and IP address on to the Port-channel interface and hope all to work well ?
Existing config.
interface GigabitEthernet0/1
ip vrf forwarding ABC
ip address 10.10.10.1 255.255.255.248
New Port-channel config
interface port-channel 1
switchport trunk allowed vlan 1,2,3,4,5
switchport mode trunk
channel-group 1 mode on
interface GigabitEthernet0/2
Peter Paluch
It is possible to put a Layer3 EtherChannel into VRF without problems. However, the configuration would be as follows:
no switchport
no switchport
Notice that the no switchport commands must be present on the physical interfaces, removing the Layer2 switching functionality from the Gi0/1 and Gi0/2 before creating an L3 EtherChannel.
Best regards,
Peter
Thanks Peter. I believe Gig 0/1 and 0/2 are native layer 3 interface but I will keep no switchport in mind when configuring.
Salmaa
Hi Salmaa,
Oh, on 6500 and similar platforms, they are L3 by default - you're right. I am more accustomed to 3560 and similar which default to L2 operation. In any case - if they are L3 by default then all the switchport mode trunk and switchport trunk ...  commands you've indicated in your config have no meaning anyway.
Best regards,
Peter
