vrf Mgmt-vrf (managent) issue
anton.caldeir
Hi all,
-I'm trying to configure a interface loopback under default vrf Mgmt-vrf and the follow log appears:
%IOSXE_MGMTVRF-3-INTF_ATTACH_FAIL: Management VRF attach to mgmt loopback failed
%LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback100, changed state to up
%LINK-3-UPDOWN: Interface Loopback100, changed state to up
-The interface loopback 100 is up, but when i ping the router gateway ip off the local network with source address loopback 100, the ping fails:
Switch#ping vrf Mgmt-vrf 192.168.66.1 source loopback 100
Sending 5, 100-byte ICMP Echos to 192.168.66.1, timeout is 2 seconds:
Packet sent with a source address of 10.255.255.118
Success rate is 0 percent (0/5)
-If i ping without source address, no problem....
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 m
- NOTE: The router gateway have a static route towards the switch loopback 100, through int gi0/0 of management vrf Mgmt-vrf ... so it is not a routing problem...
The Switch is a C9200L-48P-4X with version 17.07.01
I google for the logs... but did not find nothing.. can some one help??
Tanks
Fernando
Hi @anton.caldeir ,
It definitely looks like a bug. I would go with a non default VRF as a workaround, if that works for you.
7 Replies 7
Harold Ritter
Hi @anton.caldeir ,
Can you please provide the output for the following command:
show running | sec vrf
Interesting... not showing any interfaces associated with the vrf:
Switch#sh run | sec vrf
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
vrf forwarding Mgmt-vrf
But if i do:
Switch#sh run vrf Mgmt-vrf
Building configuration...
Current configuration : 314 bytes
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
interface GigabitEthernet0/0
ip address 192.168.66.4 255.255.255.248
interface Loopback100
ip address 10.255.255.118 255.255.255.255
why this behavior ?
Thanks Harold for the help...
Hi @anton.caldeir ,
Your configuration looks good.
Can you provide the output for the following command:
show ip route vrf Mgmt-vrf
Routing Table: Mgmt-vrf
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, m - OMP
n - NAT, Ni - NAT inside, No - NAT outside, Nd - NAT DIA
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static
route
H - NHRP, G - NHRP registered, g - NHRP registration summary
o - ODR, P - periodic downloaded static route, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
& - replicated local route overrides by connected
Gateway of last resort is not set
10.0.0.0/32 is subnetted, 1 subnets
C 10.255.255.118 is directly connected, Loopback100
192.168.66.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.66.0/29 is directly connected, GigabitEthernet0/0
L 192.168.66.4/32 is directly connected, GigabitEthernet0/0
Hi @anton.caldeir ,
Hello
The default mgt vrf should really only used for a mgt interface it should not be shared with any other interface, if yo crease a non default vrf and assign both of these interfaces a member of that new vrf what result do you get then?
Kind Regards
Paul
If i test with a non default vrf everything ok ...
