VRF not working with OSPF
ankitohc
I am trying to configure the VRF and connectivity between common router and Tenant-A. Can somone please help me with configuration and find what mistake am I doing ?
Common#show run
Common#show running-config
Building configuration...
Current configuration : 3431 bytes
! Last configuration change at 03:03:06 UTC Fri Feb 9 2024
version 15.9
hostname Common
boot-start-marker
boot-end-marker
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip vrf Tenant-A
ip vrf Tenant-B
ip vrf Tenant-C
ip cef
no ipv6 cef
redundancy
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.2
encapsulation dot1Q 2
ip vrf forwarding Tenant-A
ip address 192.0.2.1 255.255.255.252
interface GigabitEthernet0/0.3
encapsulation dot1Q 3
ip vrf forwarding Tenant-B
ip address 198.51.100.1 255.255.255.252
interface GigabitEthernet0/0.4
encapsulation dot1Q 4
ip vrf forwarding Tenant-C
ip address 203.0.113.1 255.255.255.252
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospf 1 vrf Tenant-A
router-id 1.1.1.1
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ipv6 ioam timestamp
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
login
transport input none
no scheduler allocate
end
______________________________________________
Tenant-A
Tenant-A#SHOW RUN
Tenant-A#SHOW RUNning-config
Current configuration : 2999 bytes
! Last configuration change at 03:02:58 UTC Fri Feb 9 2024
version 15.9
hostname Tenant-A
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip cef
no ipv6 cef
redundancy
ip address 192.0.2.2 255.255.255.252
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router ospf 1
no ip http server
ipv6 ioam timestamp
22 Replies 22
ankitohc
Common#show run
Current configuration : 3546 bytes
version 15.9
hostname Common
boot-start-marker
boot-end-marker
no aaa new-model
no mmi pvc
ip vrf Tenant-A
ip vrf Tenant-B
ip vrf Tenant-C
ip cef
no ipv6 cef
redundancy
no ip address
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
router-id 1.1.1.1
router ospf 2 vrf Tenant-B
router-id 3.3.3.3
router ospf 3 vrf Tenant-C
router-id 5.5.5.5
no ip http server
ipv6 ioam timestamp
NOW add VRF-lite capability and check the prefix
MHM
I did that already but OSPF is not showing in routing table for each VRF - Even I don't see the O in routing table for Tenant-A
Hello
Do you have connecitvity between the Common rtr and TenantA rtr
Common rtr
ping vrf Tenant-A 192.0.2.2
If you do not then make sure the port between the tenantA rtr and the switch in is vlan 2
and the trunk port upstream from switch to the common rtr is tagging vlan 2
If you do have connecitivity check the ospf network type between those two rts
sh ip ospf int brief
debug ip ospf adjecencieis
Kind Regards
Paul
common router has connectivity to Tenant-A
ankitohc
Common#SHOW IP ospf route
OSPF Router with ID (5.5.5.5) (Process ID 3)
Base Topology (MTID 0)
Area BACKBONE(0)
Intra-area Route List
* 203.0.113.0/30, Intra, cost 1, area 0, Connected
via 203.0.113.1, GigabitEthernet0/0.4
First Hop Forwarding Gateway Tree
203.0.113.1 on GigabitEthernet0/0.4, count 1
OSPF Router with ID (3.3.3.3) (Process ID 2)
Area BACKBONE(0)
* 198.51.100.0/30, Intra, cost 1, area 0, Connected
via 198.51.100.1, GigabitEthernet0/0.3
198.51.100.1 on GigabitEthernet0/0.3, count 1
OSPF Router with ID (1.1.1.1) (Process ID 1)
Area BACKBONE(0)
* 192.0.2.0/30, Intra, cost 1, area 0, Connected
via 192.0.2.1, GigabitEthernet0/0.2
192.0.2.1 on GigabitEthernet0/0.2, count 1
Common#
Can I see SW config ?
MHM
In the original post there was a config for Tenant-A. In that config I see only a single interface with an IP address, and that is the one that connects to Common. So there is nothing for OSPF to advertise.
Rick
