VRF over Multililink PPP
k-gerasymenko
Hello community,
                       PE                                                 CE
    MPLS                  multilink PPP via E1
I am looking for a solution for the following problem:
We have a PE router ASR 901 and CE router ASR 901. They connected with three E1 ports using multilink PPP. Forwarding packets via PPP link is working. I can ping each other routers (via interface Multilink).
After that I have assigned multilink interface on PE in VRF I cannot ping peers multilink interfaces on both PE and CE.
IOS XE: Version 15.3(3)S1
PE config:
interface Multilink1
 ip vrf forwarding TEST
 ip address 172.1.1.1 255.255.255.252
 no peer neighbor-route
 ppp multilink
 ppp multilink group 1
interface Serial0/0:0
 no ip address
 encapsulation ppp
 ppp multilink
interface Serial0/1:0
 no ip address
 encapsulation ppp
 ppp multilink
interface Serial0/2:0
 no ip address
 encapsulation ppp
 ppp multilink
CE config:
 ip address 172.1.1.2 255.255.255.252
 ppp multilink
 no ip address
 encapsulation ppp
 ppp multilink
 no ip address
 encapsulation ppp
 ppp multilink
 no ip address
 encapsulation ppp
 ppp multilink
Anyone met the same problem?Any idea how to solve this?
Hi gerasymenko,
you are working from PE so please check you are pinging right way:
ping vrf TEST 172.1.1.2
I think it should be reachable, not sure but T1 ports using multilink PPP works fine.
kazim
Hi!
I have tried all options of ping . I thought too it should be reachable. I can work from CE too. It is not working from both side. The IP of local and remote interfaces are unreachable.
