vrf route issues
i_hanu
Hi!
I have a problem with the below network, on PE1 (BUH04) I have received routes from the direct connected client (MED 01) and from the one remote one (the one connected with PE4 (BUH04)), and on PE4 I receive routes only from the MED 02.
I attached photos with confiuguration on BUH01, BUH04 and the network map.
2 Accepted Solutions
Harold Ritter
Hi @i_hanu ,
The network statement on BUH01 is incorrect. It should be
network 172.16.41.0 mask 255.255.255.0
Hi @i_hanu ,
Can you post the updated configuration.
Harold Ritter
Hi @i_hanu ,
it's the same thing
Hi @i_hanu ,
sorry, my mistake
I saw the mistake.
