VRF route leaking with static routes fails
cosmingrosu
I have the following topology in EVE-NG:
My goal is to allow Customer 2 clients (VPC4 and VPC5) to connect to Customer 1's FTP server.
ISP router has the following configuration:
ISP#show run
Building configuration...
Current configuration : 3520 bytes
! Last configuration change at 18:09:41 UTC Sun Mar 10 2024
version 15.9
hostname ISP
boot-start-marker
boot-end-marker
vrf definition Customer1
address-family ipv4
exit-address-family
vrf definition Customer2
address-family ipv4
exit-address-family
vrf definition Customer3
address-family ipv4
exit-address-family
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip domain lookup
ip cef
no ipv6 cef
redundancy
interface GigabitEthernet0/0
vrf forwarding Customer1
duplex full
speed auto
media-type rj45
interface GigabitEthernet0/1
vrf forwarding Customer2
ip address 172.16.1.1 255.255.255.0
duplex full
speed auto
media-type rj45
interface GigabitEthernet0/2
vrf forwarding Customer3
ip address 10.1.1.1 255.255.255.0
duplex full
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
shutdown
duplex full
speed auto
media-type rj45
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 172.16.1.0 255.255.255.0 GigabitEthernet0/1
ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0
ip route vrf Customer1 172.16.1.0 255.255.255.0 172.16.1.1 global
ip route vrf Customer2 192.168.1.200 255.255.255.255 192.168.1.1 global
ipv6 ioam timestamp
control-plane
line con 0
line aux 0
line vty 0 4
login
transport input none
no scheduler allocate
end
ISP#
Routing tables:
Global:
ISP#show ip route
Gateway of last resort is not set
172.16.0.0/24 is subnetted, 1 subnets
S 172.16.1.0 is directly connected, GigabitEthernet0/1
S 192.168.1.0/24 is directly connected, GigabitEthernet0/0
ISP#
Customer1:
ISP#show ip route vrf Customer1
S 172.16.1.0 [1/0] via 172.16.1.1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, GigabitEthernet0/0
L 192.168.1.1/32 is directly connected, GigabitEthernet0/0
ISP#
Customer2:
ISP# show ip route vrf Customer2
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.16.1.0/24 is directly connected, GigabitEthernet0/1
L 172.16.1.1/32 is directly connected, GigabitEthernet0/1
192.168.1.0/32 is subnetted, 1 subnets
S 192.168.1.200 [1/0] via 192.168.1.1
ISP#
From ISP router I can ping every client using ping vrf <vrf_name> <client_ip_address> (ping vrf Customer1 192.168.1.200
), but when I try to ping from VPC4 (172.16.1.199) to the FTP (192.168.1.200) server, the ping fails.
Could you tell me what am I doing wrong?
2 issues I can possibly see are you dont have INSIDE?OUTSIDE interfaces defined on your ISP router. Secondly your static routes are pointing to the global table but Customer 1 is on the Customer 1 VRF.
-David
Harold Ritter
Hi @cosmingrosu ,
Try with the following static routes instead:
no ip route 172.16.1.0 255.255.255.0 GigabitEthernet0/1
no ip route 192.168.1.0 255.255.255.0 GigabitEthernet0/0
no ip route vrf Customer1 172.16.1.0 255.255.255.0 172.16.1.1 global
no ip route vrf Customer2 192.168.1.200 255.255.255.255 192.168.1.1 global
ip route vrf Customer1 172.16.1.199 255.255.255.255 GigabitEthernet0/1 172.16.1.199
ip route vrf Customer1 172.16.1.200 255.255.255.255 GigabitEthernet0/1 172.16.1.200
ip route vrf Customer2 192.168.1.200 255.255.255.255 GigabitEthernet0/0 192.168.1.200
Hello
You just need to advertise statically each vrf host/subnet into the other vrf route table has shown by @Harold Ritter
Kind Regards
Paul
