VRF route-target routing
anonymousID
I have a four router setup like this:
C1---P1---P2---C2
C1 and C2 just use their global routing table. P1 and P2 have two VRF's, customer and backbone. I have the C1 and C2 connections tagged in the customer VRF and the P1 to P2 connection in the backbone VRF. Is there any way to distribute the customer vrf table between C1 and C2 without having the backbone routes including while being limited to just using route-targets? What is the best way to accomplish this goal?
balaji.bandi
What is the issue you see when you doing route target import and export.
BB
BB
I'm seeing all the backbone routes in the customer VRF.
Could you show your VRFs and BGP configuration?
a.alekseev
Level 7
Level 7
run mpls between P1 and P2
