Cisco ME3600x Switch Local user Credential not accepting
Zain Khan
i am using Cisco ME3600x switch, when i user command login local its not accepting password while logout, also whenever I create local user like
Conf# username test privilege 3 password test
it doesn't login/accept the credentials. can anyone suggest what could be the possibility
Zain Khan
https://www.linkedin.com/in/forzain/
5 Replies 5
johnd2310
Level 8
Level 8
What is your aaa configuration?
John
**Please rate posts you find helpful**
no aaa new-model
i am creating users on Switch
Zain Khan
hi,
just to clear, you're issuing the command in global config mode?
Switch(config)#username <USER> privilege <LEVEL> secret <PW>
kindly post the exact command and error you get.
Hi @johnlloyd_13
yes i am issuing in Global Config Mode and the same command that you mentioned
there is no error the thing is whenever i created any user like
Switch(config)#username <TEST> privilege <5> secret <TEST123>
and logout for verification and i entered the created username password it does not login into the switch
Zain Khan
hi,
how do you login? console or via SSH?
you'll need to 'login local' under line config (if you're not using AAA):
line con 0
login local
line vty 0 4
login local
