VRF static routes
NickOz
Hi, it is my first time configuring a Nexus switch, and the first time I ran across terms such as VRF.
I did some digging and I understood the concept.
I need to configure a nexus switch (3048) and don't need to use VRFs.
When I add static routes with the following configuration:
IP route 10.68.2.0 255.255.255.0 192.168.68.2/24
I see 2 lines below each route:
(not installed in urib)
rnh(installed in urib)
When I add the route without the VRF context, it is automatically set in the default VRF, In both scenarios (If I specify the VRF and if I don't) the routes aren't installed properly.
Because I do not need VRFs, is there any way to disable them?
If not, what issue is there with the static routes?
Thank you
balaji.bandi
If you want to do normal Global routing just config as below :
config t
ip route 10.68.2.0/24 192.168.68.2
end
Prerequisites for Static Routing
Static routing has the following prerequisites:
  • If the next-hop address for a static route is unreachable, the static route is not added to the unicast routing table..
I have only provided based on the requirement, i think you have features and other configured already.
BB
