VRF through GRE Tunnel
linus-ardstal
Hi! I am sitting with a topology of:
PC1 -- SW1 -- R1 -- SW2 -- PC2
I am trying to configure a GRE tunnel between SW1 and SW2, but I cannot manage to make it work. Can someone help out? See below config. I have been fooling around a bit with the routes, but nothing worked for me so far!
---SW1---
interface Tunnel0
vrf forwarding RED
ip address 100.100.100.1 255.255.255.0
tunnel source GigabitEthernet0/0
tunnel destination 20.20.20.1
interface GigabitEthernet0/0
no switchport
ip address 192.168.100.2 255.255.255.0
negotiation auto
interface GigabitEthernet0/1
switchport access vlan 10
switchport mode access
negotiation auto
interface Vlan10
vrf forwarding RED
ip address 10.10.10.1 255.255.255.0
ip route 20.20.20.0 255.255.255.0 GigabitEthernet0/0
ip route vrf RED 20.20.20.0 255.255.255.0 GigabitEthernet0/0 192.168.100.1
---R1---
ip address 192.168.100.1 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 192.168.200.1 255.255.255.0
duplex auto
speed auto
media-type rj45
ip route 10.10.10.0 255.255.255.0 GigabitEthernet0/0
ip route 20.20.20.0 255.255.255.0 GigabitEthernet0/1
---SW2---
interface Tunnel0
vrf forwarding RED
ip address 100.100.100.2 255.255.255.0
tunnel destination 10.10.10.1
no switchport
ip address 192.168.200.2 255.255.255.0
negotiation auto
negotiation auto
interface Vlan10
vrf forwarding RED
ip address 20.20.20.1 255.255.255.0
ip route vrf RED 10.10.10.0 255.255.255.0 GigabitEthernet0/0 192.168.200.1
Harold Ritter
Hi @linus-ardstal ,
The tunnel source on one side needs to match the tunnel destination on the other side and vice versa.
Currently you have:
SW1:
tunnel source: 192.168.100.2
tunnel destination: 20.20.20.1
SW2:
tunnel source: 192.168.200.2
tunnel destination: 10.10.10.1
One more thing, the tunnel source and destination need to be reachable via the global routing table, unless you config "tunnel vrf RED" in the tunnel interface.
I would suggest the following changes for the tunnel to work for you.
SW1:
interface Tunnel0
vrf forwarding RED
tunnel destination 192.168.200.2
ip route 192.168.200.2 255.255.255.255 192.168.100.1
no ip route 20.20.20.0 255.255.255.0 GigabitEthernet0/0
no ip route vrf RED 20.20.20.0 255.255.255.0 GigabitEthernet0/0 192.168.100.1
ip route vrf RED 20.20.20.0 255.255.255.0 100.100.100.2
SW2:
interface Tunnel0
vrf forwarding RED
tunnel destination 192.168.100.2
ip route 192.168.100.2 255.255.255.255 192.168.200.1
no ip route 10.10.10.0 255.255.255.0 GigabitEthernet0/0
no ip route vrf RED 10.10.10.0 255.255.255.0 GigabitEthernet0/0 192.168.200.1
ip route vrf RED 10.10.10.0 255.255.255.0 100.100.100.1
R1:
no ip route 20.20.20.0 255.255.255.0 GigabitEthernet0/1
Are you use you run
Ip routing in both SW?
Also what you use SW? Or you want to test gre with vlan.
MHM
