VRF - Unreachable NH Issue
chanjohn01
I'm practicing VRFs in GNS3, I have four routers: PE-1, PE-2, CustA-HQ and CustA-Remote. I'm unable to ping CustA-HQ from PE-2, but can ping the interface to which it connects on PE-1. When running debug ip packet detail on both CustA-HQ and PE-2, I noticed the following error:
****CustA-HQ*****
Mar 10 22:08:26.791: FIBfwd-proc: CustA_HQ:0.0.0.0/0 not enough info to forward via fib (none none)
*Mar 10 22:08:26.791: FIBipv4-packet-proc: packet routing failed
*Mar 10 22:08:26.791: IP: s=10.1.1.1 (local), d=10.2.2.20, len 100, unroutable
*Mar 10 22:08:26.791:     ICMP type=0, code=0
****PE-2****
PE-2#ping vrf CustA_Remote ip 10.1.1.1 repeat 10
*Mar 10 23:07:44.868: FIBipv4-packet-proc: route packet from (local) src 10.2.2.20 dst 10.1.1.1
*Mar 10 23:07:44.868: FIBfwd-proc: CustA_Remote:10.1.1.0/24 process level forwarding
*Mar 10 23:07:44.869: FIBfwd-proc: depth 0 first_idx 0 paths 1 long 0(0)
*Mar 10 23:07:44.869: FIBfwd-proc: try path 0 (of 1) v4-rcrsv-1.1.1.10 first short ext DCBB9B4(0)
*Mar 10 23:07:44.870: FIBfwd-proc: v4-rcrsv-1.1.1.10 valid short mbl
*Mar 10 23:07:44.870: FIBfwd-proc: label[0] 20 connid 0 link ILLEGAL
*Mar 10 23:07:44.870: FIBfwd-proc: ip_pak_table 2 ip_nh_table 0 if none nh 1.1.1.10 deag 0 chg_if 0 via fib FC09370 path type recursive
*Mar 10 23:07:44.870: FIBfwd-proc: depth 1 first_idx 0 paths 1 long 0(0)
*Mar 10 23:07:44.871: FIBfwd-proc: try path 0 (of 1) v4-anh-1.1.1.1-Gi0/0 first short ext DCBBA14(0)
*Mar 10 23:07:44.871: FIBfwd-proc: v4-anh-1.1.1.1-Gi0/0 valid short
*Mar 10 23:07:44.871: FIBfwd-proc: label[1] 3 connid 0 link TAG
*Mar 10 23:07:44.872: FIBfwd-proc: ip_pak_table 2 ip_nh_table 65535 if GigabitEthernet0/0 nh 1.1.1.1 deag 0 chg_if 0 via fib 0 path type attached nexthop
*Mar 10 23:07:44.872: FIBfwd-proc: packet routed to GigabitEthernet0/0 1.1.1.1(2) with label 20
*Mar 10 23:07:44.873: FIBipv4-packet-proc: packet routing succeeded
Success rate is 0 percent (0/10)
* PE-1 Config *
Building configuration...
Current configuration : 4421 bytes
! Last configuration change at 23:28:10 UTC Sat Mar 10 2018
version 15.5
service password-encryption
hostname PE-1
boot-start-marker
boot-end-marker
vrf definition CustA_HQ
rd 100:10
route-target export 100:10
route-target import 100:10
route-target import 100:20
address-family ipv4
exit-address-family
vrf definition CustA_Remote
rd 100:20
route-target export 100:20
address-family ipv4
exit-address-family
no aaa new-model
ethernet lmi ce
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip cef
no ipv6 cef
mpls label protocol ldp
mpls ldp password required
mpls ldp neighbor 2.2.2.20 password 7 09415E050A
mpls ldp session protection
no mpls ip propagate-ttl forwarded
redundancy
no cdp log mismatch duplex
no cdp run
ip tcp synwait-time 5
interface Loopback0
description /// MPLS MP-BGP LOOPBACK ///
ip address 1.1.1.10 255.255.255.255
interface Loopback10
description /// VRF CustA_HQ IGP LOOPBACK ///
ip address 10.10.10.10 255.255.255.255
interface GigabitEthernet0/0
ip address 1.1.1.1 255.255.255.252
ip ospf 100 area 0
duplex auto
speed auto
media-type rj45
mpls ip
interface GigabitEthernet0/1
vrf forwarding CustA_HQ
ip address 10.1.1.10 255.255.255.0
duplex full
speed 1000
router ospf 10 vrf CustA_HQ
router-id 10.10.10.10
log-adjacency-changes detail
network 10.1.1.0 0.0.0.255 area 0
network 10.10.10.10 0.0.0.0 area 0
router ospf 100
router-id 1.1.1.10
network 1.1.1.10 0.0.0.0 area 0
router bgp 100
bgp log-neighbor-changes
neighbor 2.2.2.20 remote-as 100
neighbor 2.2.2.20 update-source Loopback0
address-family vpnv4
  neighbor 2.2.2.20 activate
  neighbor 2.2.2.20 send-community extended
exit-address-family
address-family ipv4 vrf CustA_HQ
  network 10.1.1.0 mask 255.255.255.0
  redistribute ospf 10 metric 3
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
mpls ldp router-id Loopback0 force
control-plane
* CustA-HQ Config *
Current configuration : 1893 bytes
! Last configuration change at 23:23:25 UTC Sat Mar 10 2018
version 15.2
hostname CustA-HQ
boot-start-marker
boot-end-marker
rd 100:10
address-family ipv4
exit-address-family
rd 100:20
address-family ipv4
exit-address-family
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
ip address 10.10.10.1 255.255.255.255
ip address 10.1.1.1 255.255.255.0
media-type gbic
speed 1000
duplex full
negotiation auto
interface Ethernet1/0
ip address 1.0.0.1 255.0.0.0
duplex full
capability vrf-lite
redistribute bgp 100 metric 5 subnets
network 1.0.0.0 0.255.255.255 area 0
network 10.10.10.1 0.0.0.0 area 0
no ip http server
control-plane
end
* PE-2 Config *
Current configuration : 4329 bytes
! Last configuration change at 22:31:58 UTC Sat Mar 10 2018
version 15.5
hostname PE-2
boot-start-marker
boot-end-marker
rd 100:10
address-family ipv4
exit-address-family
rd 100:20
address-family ipv4
exit-address-family
no aaa new-model
ethernet lmi ce
no mmi pvc
no ip domain lookup
ip cef
no ipv6 cef
mpls ldp neighbor 1.1.1.10 password mpls
redundancy
interface Loopback0
ip address 2.2.2.20 255.255.255.255
interface Loopback20
description /// VRF CustA_Remote IGP LOOPBACK ///
ip address 20.20.20.20 255.255.255.255
ip address 1.1.1.2 255.255.255.252
ip ospf 100 area 0
duplex auto
speed auto
media-type rj45
mpls ip
vrf forwarding CustA_Remote
ip address 10.2.2.20 255.255.255.0
duplex full
speed 1000
router ospf 100
router-id 2.2.2.20
passive-interface default
no passive-interface GigabitEthernet0/0
network 2.2.2.20 0.0.0.0 area 0
router bgp 100
neighbor 1.1.1.10 remote-as 100
neighbor 1.1.1.10 update-source Loopback0
  neighbor 1.1.1.10 activate
  neighbor 1.1.1.10 send-community extended
exit-address-family
address-family ipv4 vrf CustA_Remote
  network 10.2.2.0 mask 255.255.255.0
  redistribute ospf 20 metric 3
exit-address-family
no ip http server
control-plane
**REMAINING OUTPUT OMITTED**
* CustA-Remote Config *
Current configuration : 1839 bytes
! Last configuration change at 23:45:30 UTC Sat Mar 10 2018
version 15.2
hostname CustA_Remote
boot-start-marker
boot-end-marker
rd 100:10
address-family ipv4
exit-address-family
rd 100:20
address-family ipv4
exit-address-family
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
ip address 20.20.20.1 255.255.255.255
ip address 10.2.2.1 255.255.255.0
media-type gbic
speed 1000
duplex full
negotiation auto
ip address 2.0.0.1 255.0.0.0
duplex full
router ospf 20 vrf CustA_Remote
router-id 20.20.20.1
network 2.0.0.0 0.255.255.255 area 0
network 10.2.2.0 0.0.0.255 area 0
network 20.20.20.1 0.0.0.0 area 0
no ip http server
control-plane
end
PE-1#sh ip bgp vpnv4 all
BGP table version is 35, local router ID is 10.10.10.10
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 100:10 (default for vrf CustA_HQ)
*>  1.0.0.0             10.1.1.1                 3                 32768 ?
*>  10.1.1.0/24       0.0.0.0                  0                 32768 i
*>i 10.2.2.0/24      2.2.2.20                 0    100               0 i
Route Distinguisher: 100:20 (default for vrf CustA_Remote)
PE-1#sh ip route vrf CustA_HQ
Routing Table: CustA_HQ
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
Gateway of last resort is not set
O     1.0.0.0/8 [110/11] via 10.1.1.1, 01:34:01, GigabitEthernet0/1
      10.0.0.0/8 is variably subnetted, 3 subnets, 2 masks
C        10.1.1.0/24 is directly connected, GigabitEthernet0/1
L        10.1.1.10/32 is directly connected, GigabitEthernet0/1
B        10.2.2.0/24 [200/0] via 2.2.2.20, 00:00:37
PE-1#
CustA-HQ#sh ip route vrf CustA_HQ
      1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        1.0.0.0/8 is directly connected, Ethernet1/0
L        1.0.0.1/32 is directly connected, Ethernet1/0
      10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        10.1.1.0/24 is directly connected, GigabitEthernet0/0
L        10.1.1.1/32 is directly connected, GigabitEthernet0/0
CustA-HQ#
      10.0.0.0/32 is subnetted, 1 subnets
C        10.10.10.1 is directly connected, Loopback10
CustA-HQ#
PE-2#sh ip bgp vpnv4 all
BGP table version is 52, local router ID is 20.20.20.20
              r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
              x best-external, a additional-path, c RIB-compressed,
*>i 1.0.0.0             1.1.1.10                 3    100      0 ?
*>i 10.1.1.0/24      1.1.1.10                 0    100      0 i
*>  10.2.2.0/24      0.0.0.0                  0         32768 i
PE-2#sh ip route vrf CustA_Remote
Routing Table: CustA_Remote
B     1.0.0.0/8 [200/3] via 1.1.1.10, 00:05:40
B        10.1.1.0/24 [200/0] via 1.1.1.10, 00:05:40
C        10.2.2.0/24 is directly connected, GigabitEthernet0/1
L        10.2.2.20/32 is directly connected, GigabitEthernet0/1
PE-2#
PE-2#ping vrf CustA_Remote ip 10.1.1.10 (Gi0/0 on PE-1 - connects to CustA-HQ)
Sending 5, 100-byte ICMP Echos to 10.1.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/4/8 ms
CustA_Remote# sh ip route vrf CustA_Remote
C        10.2.2.0/24 is directly connected, GigabitEthernet0/0
L        10.2.2.1/32 is directly connected, GigabitEthernet0/0
CustA_Remote#
CustA_Remote#sh ip route
      2.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C        2.0.0.0/8 is directly connected, Ethernet1/0
L        2.0.0.1/32 is directly connected, Ethernet1/0
      20.0.0.0/32 is subnetted, 1 subnets
C        20.20.20.1 is directly connected, Loopback20
CustA_Remote#
CustA_Remote#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
20.20.20.20       1   FULL/BDR        00:00:33    10.2.2.20       GigabitEthernet0/0
CustA_Remote#
Any assistance greatly appreciated
Harold Ritter
Level 12
Level 12
From the output above, it looks like CustA-HQ does not have route back to 10.2.2.0/24. You advertise it via BGP, but never redistrbute it from BGP to OSPF, as per your OSPF config:
You have the same problem in the othet direction. 10.1.1.0/24 is advertized via BGP, but not redistribute from BGP to OSPF.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
5 Replies 5
Harold Ritter
Level 12
Level 12
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Thanks so much for replying!
I must be redistributing incorrectly. I tried the following with no success on either end:
HQ
router ospf vrf CustA_HQ
Remote
router ospf vrf CustA_Remote
Am I redistributing in the wrong place?
I've updated my configs, unfortunately still no luck. I completely started over, focusing on one half of the config at a time. It doesn't really make sense for me to work on PE-2 side, if one-way distribution isn't working yet :/
 router-id 1.1.1.10
 redistribute bgp 100 metric 100 subnets route-map BGP_TO_OSPF
router ospf 100
 router-id 1.1.1.1
 network 1.1.1.1 0.0.0.0 area 0
router bgp 100
 neighbor 2.2.2.2 remote-as 100
 neighbor 2.2.2.2 update-source Loopback0
 address-family ipv4
  bgp redistribute-internal
  neighbor 2.2.2.2 activate
  neighbor 2.2.2.2 send-community extended
 exit-address-family
 exit-address-family
  redistribute ospf 10 metric 5
 exit-address-family
ip prefix-list BGP_INTERNAL seq 5 permit 1.1.1.110/31
route-map BGP_TO_OSPF permit 10
 match ip address prefix-list BGP_INTERNAL
%%%%%%%%%%PE-1 PINGS%%%%%%%%%%%%%
PE-1#ping vrf CustA_HQ 10.1.1.10
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/8 ms
Sending 5, 100-byte ICMP Echos to 10.1.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/28/48 ms
PE-1#ping vrf CustA_HQ 1.0.0.1
Sending 5, 100-byte ICMP Echos to 1.0.0.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/28/40 ms
PE-1#ping vrf CustA_HQ 1.0.0.2
Sending 5, 100-byte ICMP Echos to 1.0.0.2, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 24/299/1084 ms
%%%%PINGS FROM PC CONNECTED TO CustA-HQ%%%%%%
PC1> ping 1.0.0.1
84 bytes from 1.0.0.1 icmp_seq=1 ttl=255 time=9.051 ms
84 bytes from 1.0.0.1 icmp_seq=2 ttl=255 time=9.007 ms
PC1> ping 10.1.1.1
84 bytes from 10.1.1.1 icmp_seq=1 ttl=255 time=15.626 ms
84 bytes from 10.1.1.1 icmp_seq=2 ttl=255 time=15.626 ms
PC1> ping 10.1.1.10
84 bytes from 10.1.1.10 icmp_seq=1 ttl=254 time=46.878 ms
84 bytes from 10.1.1.10 icmp_seq=2 ttl=254 time=31.246 ms
PC1> ping 1.1.1.110
*1.0.0.1 icmp_seq=1 ttl=255 time=15.626 ms (ICMP type:3, code:1, Destination host unreachable)
>PC1> ping 1.1.1.110
Why are you trying to ping the core link (PE1 to PE2) from PC1? This will not work and it is the expected resut. You should try pinging something in the VRF on the other side.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
were a couple of issues I realized. I was using the vrf forwarding statements incorrectly, in that I had the statement on both my "LAN" subnets and my point-to-point. that's wrong. So, I configured OSPF on the Provider routers and configured MP-BGP and OSPF between the PE's and did my redistribution from the PE's. Now I can ping between all my LAN subnets. The Provider should not see my LAN routes only its connection to the PEs. Thanks for your help! Corrected config below for anyone that may run into the same issue down the road:
******P1*******
version 15.2
hostname P1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
mpls ldp neighbor 123.0.0.2 password 7 0009030A17
mpls ldp neighbor 223.0.0.1 password 7 020B145718
interface Loopback0
 ip address 123.0.0.1 255.255.255.255
 ip address 10.1.1.1 255.255.255.252
 media-type gbic
 speed 1000
 duplex full
 negotiation auto
 mpls ip
interface GigabitEthernet1/0
 ip address 111.0.0.1 255.255.255.252
 negotiation auto
 mpls ip
router ospf 100
 router-id 123.0.0.1
 no passive-interface GigabitEthernet1/0
 network 10.1.1.0 0.0.0.3 area 0
 network 111.0.0.0 0.0.0.3 area 0
 network 123.0.0.1 0.0.0.0 area 0
 default-information originate always
no ip http server
control-plane
line con 0
 exec-timeout 120 0
 stopbits 1
end
*****PE-1*****
version 15.2
hostname PE-1
boot-start-marker
boot-end-marker
 rd 100:10
 address-family ipv4
 exit-address-family
 rd 100:20
 address-family ipv4
 exit-address-family
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
mpls ldp neighbor 123.0.0.1 password 7 151F1B0017
ip tcp path-mtu-discovery age-timer 10
interface Loopback0
 ip address 123.0.0.2 255.255.255.255
 ip address 10.1.1.2 255.255.255.252
 media-type gbic
 speed 1000
 duplex full
 negotiation auto
 mpls ip
interface FastEthernet1/0
 ip address 1.0.0.1 255.255.255.248
 duplex full
 no passive-interface FastEthernet1/0
 network 1.0.0.1 0.0.0.0 area 0
router ospf 100
 router-id 123.0.0.2
 network 10.1.1.2 0.0.0.0 area 0
 network 123.0.0.2 0.0.0.0 area 0
router bgp 100
 template peer-policy IBGP-P
  next-hop-self
  maximum-prefix 1000
 exit-peer-policy
 template peer-session IBGP-S
  remote-as 100
  description IBGP/PE Sessions
  password 7 1043191516
  version 4
  timers 5 20
 exit-peer-session
 no bgp default ipv4-unicast
 neighbor 223.0.0.2 inherit peer-session IBGP-S
 neighbor 223.0.0.2 description PE-2
 address-family ipv4
 exit-address-family
  neighbor 223.0.0.2 activate
  neighbor 223.0.0.2 send-community extended
  neighbor 223.0.0.2 inherit peer-policy IBGP-P
 exit-address-family
  network 1.0.0.0 mask 255.255.255.248
  redistribute ospf 10 metric 20 match internal external 1 external 2
 exit-address-family
no ip http server
control-plane
line con 0
 exec-timeout 120 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login
end
****P2*****
hostname P2
boot-start-marker
boot-end-marker
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
mpls ldp neighbor 223.0.0.2 password 7 141A02071F
interface Loopback0
 ip address 223.0.0.1 255.255.255.255
 ip address 10.2.2.1 255.255.255.252
 media-type gbic
 speed 1000
 duplex full
 negotiation auto
 mpls ip
 ip address 111.0.0.2 255.255.255.252
 negotiation auto
 mpls ip
router ospf 100
 router-id 223.0.0.1
 network 10.2.2.0 0.0.0.3 area 0
 network 223.0.0.1 0.0.0.0 area 0
no ip http server
control-plane
line con 0
 exec-timeout 120 0
 stopbits 1
end
**********PE-2**************
PE-2#sh run
Current configuration : 2752 bytes
! Last configuration change at 04:59:03 UTC Fri Mar 16 2018
version 15.2
hostname PE-2
boot-start-marker
boot-end-marker
 rd 100:10
 address-family ipv4
 exit-address-family
 rd 100:20
 address-family ipv4
 exit-address-family
no aaa new-model
no ip domain lookup
ip cef
no ipv6 cef
mpls ldp neighbor 223.0.0.1 password 7 1104090904
interface Loopback0
 ip address 223.0.0.2 255.255.255.255
 ip address 10.2.2.2 255.255.255.252
 media-type gbic
 speed 1000
 duplex full
 negotiation auto
 mpls ip
 ip address 2.0.0.1 255.255.255.248
 duplex full
 network 2.0.0.1 0.0.0.0 area 0
router ospf 100
 router-id 223.0.0.2
 network 10.2.2.2 0.0.0.0 area 0
 network 223.0.0.2 0.0.0.0 area 0
router bgp 100
  next-hop-self
  maximum-prefix 1000
 exit-peer-policy
  remote-as 100
  password 7 060B1F2D5F
  version 4
  timers 5 20
 exit-peer-session
 bgp router-id 223.0.0.2
 neighbor 123.0.0.2 inherit peer-session IBGP-S
 neighbor 123.0.0.2 description PE-1
 address-family ipv4
 exit-address-family
  neighbor 123.0.0.2 activate
  neighbor 123.0.0.2 send-community extended
  neighbor 123.0.0.2 inherit peer-policy IBGP-P
 exit-address-family
  network 2.0.0.0 mask 255.255.255.248
  redistribute ospf 20 metric 20 match internal external 1 external 2
 exit-address-family
no ip http server
control-plane
line con 0
 exec-timeout 120 0
 stopbits 1
end
