VRFs using VLAN interfaces
CiscoNutt
equipment: Nexus 7000 (NX-OS 6.1(2) )
I have configured several SVIs and placed them in separate VRFs.  ISIS is configured as well as BGP and they are both up and running fine.  The problem is I am having trouble routing the VRFs to the other Nexus.  I am thinking it has to do with the redistribution of connected in BGP...but I am not certain.
route-map ROUTE pemit 10
match route-type local
router bgp 10
vrf VRF1
address-family ipv4 unicast
redistribute direct route-map ROUTE
CiscoNutt
Turns out that the match route-type doesn't work...well not in my case anyway.  I also tried match interface vlan which did not work either.
I ended up using a prefix list that did exact matches on all connected class A addresses
ip prefix-list LIST permit 10.0.0.0/8 le 32
