VRRP ethernet tracking
csc010854800
R1-----------R2(PE)
   |             | eBGP
R3-----------R4(CE)
   |  VRRP  |
I want't to track the WAN ethernet interface.Currently primar router is R3 and secondary router is R4.
ethernet interface doesn't go down on router even if WAN media is down , so vrrp vrid 1 track interface gig1/0 doesn't work.
BFD and ip sla command doesn't work on my device.is there any other method so that my traffic will shift on R4.
cadet alain
if you want to use secondary when primary fails using vrrp then you must use interface tracking
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtvrrptk.html
Regards.
Alain.
cadet alain
Regards.
Alain.
