VRRP on Cisco and H3C router. Any pointer ?
smitjaden905
Hello all,
Does anyone have experience configuring VRRP on H3C and Cisco? I have two gateway routers (H3C and Cisco), and I would like both units to work together to form a VRRP group with one virtual IP as a gateway. I tried configuring the VRRP before but couldn't find a proper VRRP setting in H3C. Kindly advise.
Thanks.
M02@rt37
Hello @smitjaden905
On your H3C do display vrrp command and check if "Run Mode" is standard.
"Standard” is RFC compatible VRRP mode on H3C.
Best regards
scroll down to Page 56 of the document linked below. The page numbers are vertical, on the left side. On page 56, you find the Cisco/H3C config commands.
\https://www.offidocs.com/public/?v=ext&pdfurl=https://community.cisco.com/kxiwq67737/attachments/kxiwq67737/6016-discussions-lan-switching-routing/249536/1/142797-hpiopcookbook.pdf
