VSS compatibility
susanto.liu
Hi all ,
Need help please.
My existing chassis is 6506-E and SPV card is "VS-S720-10G"
Inventory :
PID: WS-C6506-E
NAME: "1", DESCR: "WS-X6708-10GE
NAME: "2", DESCR: "WS-X6708-10GE
NAME: "3", DESCR: "WS-X6748-GE-TX
PID: WS-F6700-CFC
PID: VS-S720-10G
PID: VS-F6K-MSFC3
PID: WS-CAC-3000W
This is support VSS ?
Because, in Cisco Doc "Virtual Switching System (VSS) Q&A" , requirement :
"VS-S720-10GE-3C".
3C , is it diference with my card ?
is it support VSS, my exisitng chassis with new chassis (SPV card "VS-S2T-10G) ?
5 Policy Feature Card 3 VS-F6K-PFC3C
8 Replies 8
Reza Sharifi
Yes, your sup supports VSS.
The correct part numbers for the sups are:
VS-S720-10G-3C
VS-S720-10G-3CXL
They both support VSS.  See table-3 in this link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-6500-virtual-switching-system-1440/product_data_sheet0900aecd806ed759.html
As long as you have an E chassis, yes.
Hi Reza,
Thank you.
I have read the document.
All document always mention supervisor with last part number 3C or 3CXL (PFC 3C ready).
No mention Spv without 3C . My spv card no 3C "VS-S720-10G".
Is it difference between "VS-S720-10G" vs "VS-S720-10G-3C" ?
The 3C is the PFC and your supervisor should have it (or the 3CXL).
so, VS-S720-10G" vs "VS-S720-10G-3C"  is difference ?
The VS-S720-10G doesn't tell us which variant it is.  It's either a -3C or -3CXL; yours is likely the former as they are less expensive.
What does show module show?
"show inventory" :
NAME: "5", DESCR: "VS-S720-10G 5 ports Supervisor Engine 720 10GE Rev. 2.1"
PID: VS-S720-10G , VID: V03,
SHOW VERSION INFO
- Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-VM), Version 12.2(33)SXH3a, RELEASE SOFTWARE (fc1)
- ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
- cisco WS-C6506-E (R7000) processor (revision 1.1) with 1040384K/8192K bytes of memory.
Processor board ID
SR71000 CPU at 600Mhz, Implementation 1284, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
20 Virtual Ethernet interfaces
51 Gigabit Ethernet interfaces
18 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
SHOW MODULE INFO
Mod Ports Card Type Model Serial No.
1 8 CEF720 8 port 10GE with DFC WS-X6708-10GE
2 8 CEF720 8 port 10GE with DFC WS-X6708-10GE
3 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX
5 5 Supervisor Engine 720 10GE (Active) VS-S720-10G
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6700-DFC3C
2 Distributed Forwarding Card WS-F6700-DFC3C
3 Centralized Forwarding Card WS-F6700-CFC
5 MSFC3 Daughterboard VS-F6K-MSFC3
oh i see, this is separate SKU.
Thank You my friend :)
