04-01-2014 09:37 PM - edited 03-04-2019 10:41 PM
Since my client is using some Cat3750 stack in their campus, and experienced loop several times . now we have 2 new core Cat6506E, we want to use VSS, if the VSS is stable enough ?
What is the cause for the Cat3750 stack loop ?
Cat3750 info:
------------------ show version ------------------
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 06-Sep-11 02:59 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
M01SW3750-01 uptime is 4 weeks, 6 days, 23 hours, 2 minutes
System image file is "flash:c3750-ipservicesk9-mz.122-55.SE4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-24P (PowerPC405) processor (revision J0) with 131072K bytes of memory.
Processor board ID CAT1110NGVJ
Last reset from power-on
9 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1B:2B:59:D0:80
Motherboard assembly number : 73-9672-09
Power supply part number : 341-0029-05
Motherboard serial number : CAT111051SG
Power supply serial number : LIT11060B5D
Model revision number : J0
Motherboard revision number : A0
Model number : WS-C3750-24PS-S
System serial number : CAT1110NGVJ
Top Assembly Part Number : 800-25860-04
Top Assembly Revision Number : B0
Version ID : V05
CLEI Code Number : CNMV1K0CRD
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24P 12.2(55)SE4 C3750-IPSERVICESK9-M
Configuration register is 0xF
04-02-2014 07:46 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
You have a "stack loop"? If so, sound like you should contact TAC although would recommend you upgrade your 55SE4 to 55SE8.
VSS is now relatively stable, at least on the VS-S720s.
