Cisco E1 interface configuration
erikbragaccna
Hello everyone,
I have a router with 2 E1 interfaces, and just aded a 3rd. How can i configure the 3rd interface so that it only recives calls? I need out bount calls to always go thorught either the first and 2nd interface and not the 3rd. Is this configuration going to be made on the interface? voice-port? Dial-peer?
Thanks!
Dragan Ilic
Level 4
Level 4
Dragan Ilic
Level 4
Level 4
You should use trunk-groups with dial-peers config...more on:
http://www.cisco.com/c/en/us/td/docs/ios/12_2/dial/configuration/guide/fdial_c/dafntpri.html#wp1024553
HTH,
Dragan
HTH,
Dragan
Thanks for the response!
I ended up finding a simple solution. I deleted the outgoing call-leg. Will try to implement trunk-groups later though! I think it will help distribuite calls evenly btweeen the interfaces.
