VSS issue with 6148 line card
Hello Guys,
When i m configuring VSS on 6500 chassis my line cards (WS-X6148A-GE-TX ) getting disabled.
Please do let me know whether it doesnt support with VSS feature
Thanks in advance
2 Accepted Solutions
francisco_1
Level 7
Level 7
Are u trying to create a VSL port-channel?
Could be wrong but i think  Virtual switch link capable interfaces are only possible on WS-X6708-10G-3C/XL and ws-x6716-10G-3CXL
haribala wrote:
no.. this is just a line card inserted.
Harish
Giuseppe is correct, it makes no difference if you are simply using as a linecard. Have a look at the VSS Q&A - Table 1 which list the hardware supported for VSS -
VSS Q&A
Jon
Giuseppe Larosa
Hello Harish,
VSS supports only 67xx series linecard what you see is expected
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053927
Hope to help
Giuseppe
francisco_1
Level 7
Level 7
Harish
VSS Q&A
Jon
