access-list for 255.255.248 subnet
I am in the proccess to change my subnet mask from 192.168.0.0/24 to 192.168.0.0/21 bit due to shortage of ip addresses
I am stuck at cisco 2811 router I as don't know exctly which access-list I need to apply.
below is my current access-list
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 2xx.xx.1xx.1xx 0.0.0.7
access-list 100 remark SDM_ACL Category=1
access-list 100 remark IPSec Rule
access-list 100 permit ip 192.168.0.0 0.0.0.255 10.0.0.0 0.255.255.255
access-list 101 remark SDM_ACL Category=4
access-list 101 remark IPSec Rule
access-list 101 permit ip 2xx.1xx.2xx.xx 0.0.0.3 host xx.xx.xx.xx
access-list 120 permit ip 192.168.0.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 130 deny   ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.31
access-list 130 deny   ip 192.168.0.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 130 permit ip 192.168.6.0 0.0.0.255 any
access-list 130 permit ip 192.168.0.0 0.0.0.255 any
access-list 130 permit ip 192.168.0.0 0.0.0.248 any
access-list 199 permit ip 192.168.0.0 0.0.0.255 192.168.6.0 0.0.0.255
Please advice
Aaron Harrison
192.168.0.0/21 = 192.168.0.0 0.0.7.255
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
thank you very much
works as I hoped it will
i gave you full raitng
If you want to work these out in future -
255.255.248.0
with a reverse mask 255 = 0 so
255.255.  = 0.0.
0 = 255
so
255.255.248.0  = 0.0.x.255
to work out what value to use for the 3rd octet ie. 248 subtract 248 from 255 so
255 - 248 = 7
so full mask =  0.0.7.255
another example  255.192.0.0
255 = 0
0 = 255
so 0.x.255.255
to get x
255 - 192 = 63
so full mask = 0.63.255.255
Jon
Thank you for the note.
I have notices that  i can't access LAN through VPN after changing to subnet as described in post above.
I understand that it's related to access-list once again and based on your explanation tried to change it but no luck so far.
I was wondering if it possible to let me know how it can be fixed.
ip local pool ippool 192.168.6.2 192.168.6.25
access-lists
access-list 1 permit 2xx.xx.1xxx.1xx 0.0.0.7
access-list 101 permit ip 2xx.1xx.2xx.xx 0.0.0.3 host 6x.xx.xx.xx
access-list 130 permit ip 192.168.0.0 0.0.7.255 any
access-list 130 deny   ip 192.168.0.0 0.0.7.255 192.168.6.0 0.0.0.31
access-list 199 permit ip 192.168.0.0 0.0.7.255 192.168.6.0 0.0.0.255
route-map nonat permit 10
match ip address 130
match interface Serial0/1/0
Thank you
