VSS on 4500X
johnelliot6
Level 2
Level 2
Attempting to setup VSS on 2 x 4500X's using the following guide:
https://supportforums.cisco.com/docs/DOC-29472
But the portchans go into suspended mode when applied to the physical Ints:
SW1:
interface Port-channel5
switchport
switchport mode trunk
switchport nonegotiate
switch virtual link 1
end
sw1#sh interface tenGigabitEthernet 1/1
TenGigabitEthernet1/1 is up, line protocol is up (connected)
SW2:
interface Port-channel10
switchport
switch virtual link 2
end
sw2#sh  interface tenGigabitEthernet 1/1
Then I add physical ports to the portchan, and it complains that trunk mode of the Ints is not compatable? (dynamic vs trunk)
sw1(config)#interface tenGigabitEthernet 1/1
sw1(config-if)#switchport mode trunk
sw1(config-if)#channel-group 5 mode on
WARNING: Interface TenGigabitEthernet1/1 placed in restricted config mode. All extraneous configs removed!
sw1(config-if)#
*Mar 11 16:37:24.004: %EC-5-CANNOT_BUNDLE2: Te1/1 is not compatible with Po5 and will be suspended (trunk mode of Te1/1 is dynamic, Po5 is trunk)
sw2(config)#interface TenGigabitEthernet1/1
sw2(config-if)#switchport mode trunk
sw2(config-if)#channel-group 10 mode on
sw2(config-if)#
*Jan 22 00:30:13.065: %EC-5-CANNOT_BUNDLE2: Te1/1 is not compatible with Po10 and will be suspended (trunk mode of Te1/1 is dynamic, Po10 is trunk)
switchport
end
no lldp transmit
no lldp receive
no cdp enable
service-policy output VSL-Queuing-Policy
If I remove "switch virtual link " from the portchans, and then re-apply them to the tenGig ints, the portchan comes up?
sw2#sh int port-channel 10
Port-channel10 is up, line protocol is up (connected)
Both switches are running 03.04.00.SG and 15.0(1r)SG7 ROM
Any help is greatly appreciated.
By seeing this log message that your physical interface is still in dynamic  mode and  disabled in the port-channel.
Please entry this below command and check the stauts. both should be match . I guess, as per your configuration you will see the difference as physical interface still in dynamic negotation mode.
show int t1/1 switchport
show int po10 sw
EX :
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: enabled
Voice VLAN: none
Please try to disable dynamic trunking mode in the physical interface and re-configure the port-channel will fix the issue.
Try this below config:
switch(config-if)#switchport mode trunk
Command rejected: An interface whose trunk encapsulation is "Auto" can not be co
nfigured to "trunk" mode. -----------------------------------------------------> normally you will get this error when you change the interface to trunk if the int in auto mode
switch(config-if)#switchport trunk encapsulation dot1q
switch(config-if)#switchport nonegotiate
VS.Suresh.
*Plz rate the usefull posts.
Thanks for the reply - As I stated in my post, if I remove "switch virtual link" from the portchans, then re-apply them to the physical Ints, the portchan comes up?
And as you can see below, negotiation of Trunking is off on both portchan and tengig1/1:
sw2#show int t1/1 switchport
Switchport: Enabled
Operational Mode: down (suspended member of bundle Po10)
Negotiation of Trunking: Off
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: ALL
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Appliance trust: none
sw2#
sw2#show int port-chan10 switchport
Switchport: Enabled
Voice VLAN: none
sw2#
