03-11-2013 10:27 PM - edited 03-04-2019 07:15 PM
Dear Friends,
i have cisco 3845 on my network now its working fine.Now one of my client is asking to they want to connect their network through my router ethernet interface.
now my doubt is 3845 router will support two different gateways.
how can i route their network they have bring new router or any solution for this.
Please any body share your idea.
srini
Solved! Go to Solution.
03-11-2013 10:49 PM
If there network doesn't have the same IP range as your you can do it with no problem, just make sure that there network doesn't leak into your and vice versa, you can do this by access list on the interface. You can use routing protocals to learn there netwrok addresses from tehir network. Do not redistribute between your routing procoll and theirs unless you need to for management purposes. I would suggest to use routemaps then to only allow the managment range.
The correct way of doing this would be with VRF, if you are not familiar with I suggest you should read up on it and see if it will suite your solution.
03-11-2013 10:49 PM
03-11-2013 11:45 PM
HI,
You can Crate Site to Site VPN. Its Better and Secure.
*** Do Rate Helpful Posts***
