VTI and IPSEC (tunnel mode ipsec is not working )
UCrypto
Dear all,
I try to vti in my lab. I got the some issue.
i cannot turn on "tunnel mode ipsec ipv4" in tunnel.
If i active that command my traffic cannot reach end to end (host to host)
I remove this command,i can reach host to host.
it is VTI restriction or my configuration error ? When i change ipsec mode to GRE ,it is also working. IPSec mode is not working.
hostname R1
ip cef
crypto isakmp policy 1
encr aes
authentication pre-share
group 2
crypto isakmp key MY_PASSWORD address 192.168.12.2
crypto ipsec transform-set MY_TRANSFORM_SET esp-aes esp-sha-hmac
mode tunnel
crypto ipsec profile IPSEC_PROFILE
set transform-set MY_TRANSFORM_SET
interface Tunnel0
ip address 12.12.12.1 255.255.255.0
tunnel source 192.168.12.1
tunnel destination 192.168.12.2
tunnel protection ipsec profile IPSEC_PROFILE
interface g1/0
ip address 192.168.1.254 255.255.255.0
interface g0/0
ip address 192.168.12.1 255.255.255.0
ip route 192.168.2.0 255.255.255.0 Tunnel0
end
hostname R2
ip cef
encr aes
group 2
crypto isakmp key MY_PASSWORD address 192.168.12.1
mode tunnel
interface Tunnel0
ip address 12.12.12.2 255.255.255.0
tunnel source 192.168.12.2
tunnel destination 192.168.12.1
interface g1/0
ip address 192.168.2.254 255.255.255.0
interface g0/0
ip address 192.168.12.2 255.255.255.0
ip route 192.168.1.0 255.255.255.0 Tunnel0
end
I think it is IOS image error .Please use c7200-adventerprisek9-mz.152-4.M8
11 Replies 11
config looks good actually. Which routers are you using, and is this a simulator or live equipment ?
What if you change:
to
crypto isakmp key MY_PASSWORD address 0.0.0.0 0.0.0.0
on both ends ?
Hello
what are you testing this on, I am asking because as far as i can see your config looks okay
Kind Regards
Paul
Hi ,
I already tried above solution that you proposed.
But still cannot . I don't know why .
I thougth i VPC is error so i change VPC to routers and test . but still got error.
please see the ping test and trace route.
if i remove  IPsec tunnel mode.i can reach each other.
Hello
It sounds like your simulation software, try gns3 and test again
Kind Regards
Paul
this looks like GNS3, which images are you using ?
Post the full configs of all 4 routers so we can lab this...
i am using c7200-advipservicesk9-mz.152-4.S5.image . if it is GNS3 error ,i am happy.i worry it cannot be work in production. Please config of all 4 router.
R1#sh run
Building configuration...
Current configuration : 1583 bytes
version 15.2
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
ip tcp synwait-time 5
encr aes
group 2
mode tunnel
interface Tunnel0
interface Ethernet0/0
no ip address
shutdown
duplex auto
interface GigabitEthernet0/0
media-type gbic
speed 1000
duplex full
negotiation auto
interface GigabitEthernet1/0
negotiation auto
interface GigabitEthernet2/0
no ip address
shutdown
negotiation auto
interface GigabitEthernet3/0
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R1#
R2#sh run
version 15.2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
encr aes
group 2
mode tunnel
interface Tunnel0
no ip address
shutdown
duplex auto
media-type gbic
speed 1000
duplex full
negotiation auto
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R2#
R3#sh run
Current configuration : 1095 bytes
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
no ip address
shutdown
duplex auto
no ip address
shutdown
media-type gbic
speed 1000
duplex full
negotiation auto
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.1.254
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#T{R}X
R3#}p
R3#
R3#termi
R3#terminal len
R3#terminal length 0
R3#sh run
version 15.2
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
no ip address
shutdown
duplex auto
no ip address
shutdown
media-type gbic
speed 1000
duplex full
negotiation auto
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R3#
R4#sh run
version 15.2
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
no ip address
shutdown
duplex auto
no ip address
shutdown
media-type gbic
speed 1000
duplex full
negotiation auto
ip address 192.168.2.1 255.255.255.0
negotiation auto
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
no ip http server
ip route 0.0.0.0 0.0.0.0 192.168.2.254
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
end
R4#
I just recreated your exact setup in GNS3, with IOSv 15.6(2)T, and it works perfectly. So I am pretty sure it is a version problem, there is nothing wrong wiith the configs.
Hi ,
Thank you for your help. I already with real device and VTI with pre share key is working.
Let me know below are i am confused.
  1. Can i create IPSec tunnel Static VTI with CA ( without using pre-share key ) ?
  2. Can i setup both Static VTI tunnel and DMVPN tunnel in one router of branches ? ( i want to connet to DC1 by using IPsec with VTI and Traffice to DC2 by using DMVPN ) because DC 1 using non-cisco devices and DC2 using cisco device. branches are using cisco routers.
https://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtIPSctm.html#wp1046681
Restrictions for IPsec Virtual Tunnel Interface
IPsec Transform Set
The IPsec transform set must be configured in tunnel mode only.
P.S.
good tool https://cway.cisco.com/tools/ipsec-overhead-calc/
Do you mean I can not configure VTI with IPsec? Should I use gre over
IPsec.I can use tunnel mode only.Because I have to create two tunnel with
certificate.
