EGB failover in DMVPN
UCrypto
Dear Sir,
I am beginner in BGP. I would like to know about the EBGP .
 My Outbound traffic on CPE
All outbound traffic will go out thru primary line(12.1.3.1)
 Inbound traffic  on CPE
All inbound traffic will come in thru primary line (12.1.3.1) . How to configure.
i referenced below link but my scenario is a little different.i want to use EBGP . Which configuration part do i need to change and edit ?
http://showipbgp.com/bgp-configurations/40-cisco/71-3-1-1-cisco-dual-bgp-with-metric-redundancy.html
  • ISPs : 1
  • WAN links : 2
  • CPE : 1
  • PE : 2
  • Device : Cisco router with LAN/WAN ports.
  • WAN1 / Serial IP : 12.1.3.0/30 (mask 255.255.255.252)
  • WAN2 / Serial IP : 13.1.4.0/30 (mask 255.255.255.252)
  • LAN / Ethernet IP : 10.1.0.1/24 and 10.1.0.129/25(Secondary)
  • LAN : ISP (AS20) and Customer (AS65500)
MrBeginner
I always local-preference and prepend as below.
router bgp 65000
bgp log-neighbor-changes
network 2.2.2.0 mask 255.255.255.0
neighbor 10.1.12.1 remote-as 1
neighbor 10.1.12.1 route-map PREPEND out <===Primary Link
neighbor 10.1.12.1 route-map failoverlink in <==== Secondarily link
neighbor 12.12.12.1 remote-as 1
route-map failoverlink permit 10
set local-preference 80
route-map PREPEND permit 10
set as-path prepend 65000 65000
6 Replies 6
Larry Sullivan
Level 3
Level 3
A route-map with weight to determine outbound traffic and as-prepends to determine inbound traffic.  You can also use M.E.D. if eBGP peerings are same AS on far end.
You can have a secondary route-map for the backup link with N prepends and weight lower than default and leave the primary without a route-map.  You would then have a failover route-map configured and ready to be applied.  It would have more as-prepends than the backup and a lower weight.
Or you could have a primary route-map on the primary and a less desirable route-map on the backup with a failover route-map ready to be applied to the primary.
Hi ,
If i want to run DMVPN on this network,is it same way ?
In HUB site,I need to use different NHRP ID,different network for different ?
How to configure on spoke to HUB for failover ?
Yes, this would work over DMVPN the same way.
HUB and Spoke should use same network ID in NHRP.  Tunnel IP should be same subnet.
Example failover:
route-map FAILOVER permit 10
 set metric 15000 (higher than secondary)
 set weight 50 (lower than secondary, cisco propriety)
 set as-path prepend 12345 12345 12345 12345 12345 12345 12345 (more hops than secondary)
And you would apply this in BGP configs
Hi ,
I would like to know if we use eBGP we can’t use dynamic neighbors so we’ll have to configure them manually each site ?
Hi ,
I would like to know,should i use loopback for ebgp peering ? or should i use physical interface address.Now i am using physical address.
In my design ,with attribute is best practice for BGP fail-over (weight or local preference)?
Can i configure without using as-prepend ?
MrBeginner
router bgp 65000
