VWIC3-2MFT-T1/E1 for terminating 2 ISP
skallidu
Hello experts,
I have suggested VWIC3-2MFT-T1/E1 to one of my customer in order to to terminate 2 Voice PRI Lines.
I have a doubt in regards to whether we can terminate Voice PRI lines from 2 different ISP on the same line card or we need to terminate the other Voice PRI on other line card.
Please let me know if there are any known issues in this scenario.
Thanks and Regards
K Subin
5 Replies 5
skallidu
Would like to add one more information to this thread.
At this point i have already sold this card, hence if we can not terminate 2 Voice PR on the same line card.
Please let me know the possible solution and what is the best practice we should follow in such scenarios.
K Subin
paolo bevilacqua
You can terminate PRI on one or more cards.
Paolo,
So that mean's we can terminate two ISP on the same line card with out any issue's.
Correct !!!
K Subin
Hi Subin,
unless particular requirements i do believe you can do it. The question is another one.. Why don't you believe you can do it?
Alessio
You may have an issue with circuit slips if the circuits are not coming from the same master clock. In practice, that only prefent fax from working, voice is not affected.
However the problem still exists either you use one card, or two.
