VXLAN EVPN External Routing with OSPF
paul1202
I have a VXLAN EVPN Fabric and have successfully peered with an external BGP router and exchanged routes.
I now wish to peer directly with a pair of OSPF routers and redistribute specifc prefixes to them. There are about 20 discontiguous prefixes I wish to advertise out from the Fabric.
I'm not sure if I can use a combination of a route-map with a prefix-list, together with the "match route-type internal" command or if there is a better way to do it.
Please can someone share an example of how this can be done.
This link has helped me with discontiguous subnets before. It uses AND/OR logic.
Using Discontiguous Wildcard Masks in ACLs - Router Jockey
-David
Thanks David, but what I really need to know is if the following configuration would work when peering externally from the VXLAN Fabric using OSPF.
router ospf 100
vrf prod
redistribute bgp 65501 route-map BGP-TO-OSPF
route-map BGP-TO-OSPF permit 10
match ip address prefix-list DATA-CENTRE-MAN
ip prefix-list DATA-CENTRE-MAN seq 5 permit 10.202.248.64/27
ip prefix-list DATA-CENTRE-MAN seq 10 permit 10.202.252.64/27
ip prefix-list DATA-CENTRE-MAN seq 15 permit 10.202.252.128/26
hhon
Hi Paul, can you share your configuration of how you redistribute external routes including the default route into your VXLAN EVPN Fabric. I ran into an issue on this. Appreciate for sharing.
