vxlan package is layer 3 or 2
Leftz
Level 4
Level 4
Hi please see the below two picture of vxlan structures. Based on my understanding, one is considered as layer 3 package and second one is layer 2. In different travel phase, it show different structure, Is this correct?
2 Accepted Solutions
M02@rt37
Hello @Leftz
Same ! The two answer to that definition :
VxLAN is a L2 overlay technology that utilizes UDP to encapsulate L2 Ethernet frames within L3 packets, allowing for the creation of virtualized networks that can extend across L3 networks.
In VxLAN, when a packet reaches the VTEP, the outer MAC header is indeed removed. VxLAN encapsulation involves adding an outer UDP header along with a VxLAN header to the original Ethernet frame.
Best regards
it can be, the outer header is remove to routing the frame. (when routing frame the MAC is change)
but both are same.
MHM
both are same,  except one have Outer MAC header and other not Have
MHM
Leftz
Level 4
Level 4
thanks for your reply. but the top one does not have outer mac header. maybe the outer mac header is already removed when it is at vtep, right?
but both are same.
MHM
M02@rt37
Hello @Leftz
Best regards
