Bookmark
Subscribe
2505
Deny access to other VLAN and only access for Server VLAN
bryg0d
Hi everyone, I am trying to deny VLANs to each other and only be reaching server VLAN. My commands below is successful on packet tracer but failed during implementation.
ip access-list ext DenyVlans_50
permit ip 172.16.50.0 0.0.0.255 172.16.36.0 0.0.3.255 [ 172.16.36.0 /22 is my Server Vlan]
deny ip 172.16.50.0 0.0.0.255 172.16.0.0 0.0.255.255 [172.16.0.0 0.0.255.255 is the supernet of all 30 VLANs]
permit ip any any [ for internet ]
int vlan 50
ip access-group DenyVlans_50 in
From my understanding, VLAN50 will allow access to Server Vlan then deny any other VLANs inside the supernet 172.16.0.0 /16.
Now ONE ACL for all VLAN include VLAN of Server
*** the direction of this VLAN must be IN
1- from Server-> to all VLAN subnet
permit ip 172.16.36.0 0.0.3.255 172.16.0.0 0.0.255.255
2- from all VLAN subnet to Server
permit ip 172.16.0.0 0.0.255.255 172.16.36.0 0.0.3.255
2-Op for DHCP you need
permit udp any eq bootpc any eq bootps
3- from all VLAN subnet to all VLAN subnet
deny ip 172.16.0.0 0.0.255.255 172.16.0.0 0.0.255.255
4- from all VLAN subnet to ANY
permit ip 172.16.0.0 0.0.255.255 any
hope this what you looking for
MHM
16 Replies 16
Can i see show access list
MHM
Hello
Ip access-list extended Vlan1
deny ip any 10.1.2.0 0.0.0.255  (vlan 2)
deny ip any 10.1.3.0 0.0.0.255  (vlan 3)
etc...
permit ip any any
int vlan 1
ip access-group Vlan1 IN
Ip access-list extended Vlan2
deny ip any 10.1.1.0 0.0.0.255  (vlan 1)
etc...
permit ip any any
int vlan 2
ip access-group Vlan2 IN
etc..
Kind Regards
Paul
Hi Paul,
This is too many since I have almost 30 VLANS. Is there any way to lessen the lines of command?
Hello
you would have to apply an acl to each L3  anyway to negate the communication between them - as for the mutiple acl entries you may be able to summerise the ip range but again you need to be careful not to deny/permit unwarranted traffic or Only permit traffic you wish to allow and have a default deny action.
Alternatively put each L3 svi in its own VRF apart from the server vlan
Kind Regards
Paul
DaviRocK!
Double-check the subnet masks in your ACL. For example, if your server VLAN is really just a /28 subnet, the mask in the ACL should reflect that. The entry permit ip 172.16.50.0 0.0.0.255 172.16.36.0 0.0.3.255 covers more than just your /28 server VLAN.
A more accurate rule might be: permit ip 172.16.50.0 0.0.0.255 172.16.36.0 0.0.0.1
logging to your ACL to troubleshoot which packets are being permitted or denied. This can provide valuable insight into what's happening:
ip access-list extended DenyVlans_50
permit ip 172.16.50.0 0.0.0.255 172.16.36.0 0.0.0.15 log
deny ip 172.16.50.0 0.0.0.255 172.16.0.0 0.0.255.255 log
permit ip any any log
Hi DaviRock,
Apologies for confusion. My Server VLAN is actually /22.
friend your ACL is correct
but let me see show access list
let check which is hit and which is not hit
MHM
Hello
@MHM Cisco World  @DaviRocK!  not sure how the acl can the be correct just applied to the server vlan when the OP suggested only the server vlan needs to accessible to all vlans - Have i missed something if so apologies to all!
Kind Regards
Paul
Not at all' you are correct.
He need change source in acl for each vlan' so that source is match vlan subnet.
But I was talking about only acl apply to vlan 50' if he use correct source then acl is ok and must work.
@bryg0d Mr @paul driver  solution is correct' but if you see it long and you need only one acl apply to all vlan svi then
Write vlan subnet
And use one supernet as source.
For example if you have vlan10 192.168.10.0/24 and vlan 20 192.168.20.0/24 you can use supernet
192.168.0.0/16 that includes all vlan subnet in Only ONE ACL
MHM
Hello
@MHM Cisco World  I would say it isn’t correct tbh - you do not require any acl in vlan 50 that’s the only vlan which doesn’t require any filtering - to negate the other vlans from communicating with each other then you would need to append an acl on each svi - either with a deny to each individual subnet or summarise the ip range and a permit for everything else or apply a permit for vlan 50 and all other traffic other than the other local vlans (again individually or summarise) or put each SVI in its own VRF.
Kind Regards
Paul
Hi MHM,
I believe that's correct. I need to implement the ACL on all Vlan except Server Vlan but using it's own subnet on the ACL. Did I get that right?
Hi MHM,
ACL below is already applied on the SVI. Tried to ping test inside the core switch using IP of different SVI's but it's reachable. Will try to test later on the endpoints/pc.
MHM
Hi MHM,
Thank you. Will try to simulate the commands later.
