VXLAN with EBGP Peers - Routes Missing in VXLAN
PingWhisperer
Hello all!
I have a test VXLAN environment, that is currently hosting 4 networks between 4 9k's and everything with VXLAN is working great. I added 2 firewalls, that my 9k's connect too and get their default routes from. With that, I also added 2 DMZ's to those new firewalls and created eBGP neighbors back to my VXLAN VRF. I am getting my DMZ routes from my eBGP relationship, but what I notice is my VTEP peers dont seem to get any VXLAN routes for those new eBGP routes.
Basically, I want to be able to from any VTEP reach my new eBGP relationships and essentialy distribute those new eBGP routes into VXLAN.
I've noticed if I use OSPF and redistribute it, I can do effectively that by using redistribute in the BGP process. Yet the BGP routes dont seem to show up in VXLAN at all.
Any suggestions?
8 Replies 8
balaji.bandi
M02@rt37
Hello @PingWhisperer
Please provide us a topology of your network.
Thanks a lot.
Best regards
also add the full running configs of all devices involved, so we can (possible) lab this up...
PingWhisperer
In this network, the VXLAN networks, 192.168.11.10/24 and 192.168.10.10/24 are working fine with their VXLAN topology.
The 2 DMZ networks, DMZ-1 (172.16.1.0/24) is only reachable via NXOS1, and DMZ-2 (172.16.2.0/24) is only reachable via NXOS2.
What I want/need is VPC6, to be able to reach DMZ-1. When you check the VRF on NXOS1 it has a BGP route to DMZ-1, but it does NOT share that route via VXLAN to NXOS2.
When I create OSPF neighbors instead with FW1, and I redistribute that into the BGP topolgy, it then shares the routes via VXLAN. I don't want to use OSPF, I want to use either iBGP or eBGP but need to share my routes via VXLAN.
Hopefully that makes more sense.
FW1#show running-config
Building configuration...
Current configuration : 3187 bytes
! Last configuration change at 15:12:03 UTC Tue Jan 9 2024
version 15.2
service compress-config
hostname FW1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
interface GigabitEthernet0/0
 no switchport
 ip address 208.67.222.2 255.255.255.252
 negotiation auto
interface GigabitEthernet0/1
 no switchport
 ip address 172.16.1.1 255.255.255.0
 negotiation auto
interface GigabitEthernet0/2
 negotiation auto
interface GigabitEthernet0/3
 negotiation auto
interface GigabitEthernet1/0
 negotiation auto
interface GigabitEthernet1/1
 negotiation auto
interface GigabitEthernet1/2
 negotiation auto
interface GigabitEthernet1/3
 negotiation auto
router bgp 65534
 bgp router-id 208.67.222.2
 bgp log-neighbor-changes
 network 172.16.1.0 mask 255.255.255.0
 neighbor 208.67.222.1 remote-as 65535
 neighbor 208.67.222.1 update-source GigabitEthernet0/0
 neighbor 208.67.222.1 default-originate
ip forward-protocol nd
ip http server
ip http secure-server
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
control-plane
banner exec ^C
IOSv - Cisco Systems Confidential -
Supplemental End User License Restrictions
This IOSv software is provided AS-IS without warranty of any kind. Under no circumstances may this software be used separate from the Cisco Modeling Labs Software that this software was provided with, or deployed or used as part of a production environment.
By using the software, you agree to abide by the terms and conditions of the Cisco End User License Agreement at http://www.cisco.com/go/eula. Unauthorized use or distribution of this software is expressly prohibited.
^C
banner incoming ^C
^C
banner login ^C
^C
line con 0
 logging synchronous
line aux 0
line vty 0 4
end
FW2#show running-config
Current configuration : 3146 bytes
! Last configuration change at 15:38:46 UTC Tue Jan 9 2024
version 15.2
hostname FW2
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
 no switchport
 ip address 108.67.222.2 255.255.255.252
 negotiation auto
 no switchport
 ip address 172.16.2.1 255.255.255.0
 negotiation auto
 negotiation auto
 negotiation auto
 negotiation auto
 negotiation auto
 negotiation auto
 negotiation auto
router bgp 65534
 bgp router-id 108.67.222.2
 network 172.16.2.0 mask 255.255.255.0
 neighbor 108.67.222.1 remote-as 65535
 neighbor 108.67.222.1 update-source GigabitEthernet0/0
ip http server
control-plane
banner exec ^C
^C
banner incoming ^C
^C
banner login ^C
^C
line con 0
 logging synchronous
line aux 0
line vty 0 4
end
NXOS1# show running-config
!Command: show running-config
!Running configuration last done at: Tue Jan  9 15:38:41 2024
!Time: Tue Jan  9 15:49:48 2024
version 10.3(4a) Bios:version
hostname NXOS1
vdc NXOS1 id 1
  limit-resource vlan minimum 16 maximum 4094
  limit-resource vrf minimum 2 maximum 4097
  limit-resource port-channel minimum 0 maximum 511
  limit-resource m4route-mem minimum 58 maximum 58
  limit-resource m6route-mem minimum 8 maximum 8
nv overlay evpn
feature ospf
feature bgp
feature interface-vlan
feature vn-segment-vlan-based
feature nv overlay
no password strength-check
username admin password 5 $5$GFPMEJ$ZT97vgSalc27Wq9r0DhBXB/i0yuI3kd4dVsjhe.Fuw1  role network-admin
ip domain-lookup
copp profile strict
hardware access-list tcam region racl 512
hardware access-list tcam region e-racl 512
hardware access-list tcam region arp-ether 256 double-wide
snmp-server user admin network-admin auth md5 0142EC31804EDFAF7F2C60B8B0A5CC6BDDC2 priv aes-128 364BEC328312DDB3586475BAAFAFFA3598C7 localizedV2key
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
fabric forwarding anycast-gateway-mac 0000.2222.3333
vlan 1,101,1000-1001
vlan 101
  vn-segment 900001
vlan 1000
  vn-segment 5000
vlan 1001
  vn-segment 5005
vrf context VXLAN
  vni 900001
  rd auto
  address-family ipv4 unicast
    route-target both auto
    route-target both auto evpn
vrf context management
interface Vlan1
interface Vlan101
  no shutdown
  vrf member VXLAN
  ip forward
interface Vlan1000
  no shutdown
  vrf member VXLAN
  ip address 192.168.10.1/24
  fabric forwarding mode anycast-gateway
interface Vlan1001
  no shutdown
  vrf member VXLAN
  ip address 192.168.11.1/24
interface nve1
  no shutdown
  host-reachability protocol bgp
  source-interface loopback0
  member vni 5000
    suppress-arp
    ingress-replication protocol bgp
  member vni 5005
    suppress-arp
  member vni 900001 associate-vrf
interface Ethernet1/1
  no switchport
  vrf member VXLAN
  ip address 208.67.222.1/30
  no shutdown
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet1/4
  description Host Computer
  switchport access vlan 1000
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
  no switchport
  ip address 192.168.255.1/30
  ip router ospf 150 area 0.0.0.0
  no shutdown
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/10
interface Ethernet1/11
interface Ethernet1/12
interface Ethernet1/13
interface Ethernet1/14
interface Ethernet1/15
interface Ethernet1/16
interface Ethernet1/17
interface Ethernet1/18
interface Ethernet1/19
interface Ethernet1/20
interface Ethernet1/21
interface Ethernet1/22
interface Ethernet1/23
interface Ethernet1/24
interface Ethernet1/25
interface Ethernet1/26
interface Ethernet1/27
interface Ethernet1/28
interface Ethernet1/29
interface Ethernet1/30
interface Ethernet1/31
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/36
interface Ethernet1/37
interface Ethernet1/38
interface Ethernet1/39
interface Ethernet1/40
interface Ethernet1/41
interface Ethernet1/42
interface Ethernet1/43
interface Ethernet1/44
interface Ethernet1/45
interface Ethernet1/46
interface Ethernet1/47
interface Ethernet1/48
interface Ethernet1/49
interface Ethernet1/50
interface Ethernet1/51
interface Ethernet1/52
interface Ethernet1/53
interface Ethernet1/54
interface Ethernet1/55
interface Ethernet1/56
interface Ethernet1/57
interface Ethernet1/58
interface Ethernet1/59
interface Ethernet1/60
interface Ethernet1/61
interface Ethernet1/62
interface Ethernet1/63
interface Ethernet1/64
interface mgmt0
  vrf member management
interface loopback0
  ip address 1.1.1.1/32
icam monitor scale
line console
line vty
boot nxos bootflash:/nxos64-cs.10.3.4a.M.bin
router ospf 150
  router-id 1.1.1.1
router bgp 65535
  router-id 1.1.1.1
  neighbor 2.2.2.2
    remote-as 65535
    update-source loopback0
    address-family l2vpn evpn
      send-community extended
  vrf VXLAN
      network 192.168.10.0/24
      advertise l2vpn evpn
    neighbor 208.67.222.2
      remote-as 65534
      local-as 65535
      update-source Ethernet1/1
evpn
  vni 5000 l2
    rd auto
    route-target import auto
    route-target export auto
  vni 5005 l2
    rd auto
NXOS2# show running-config
!Running configuration last done at: Tue Jan  9 15:39:08 2024
!Time: Tue Jan  9 15:50:30 2024
hostname NXOS2
vdc NXOS2 id 1
nv overlay evpn
feature ospf
feature bgp
feature nv overlay
username admin password 5 $5$NOKIAD$dmSy1Fds8ExPMvgZ/g0jI0O0eGOo9.Z.6d5FmmapvXC  role network-admin
ip domain-lookup
copp profile strict
snmp-server user admin network-admin auth md5 53119D5D6FD9E2D1D4820B7A6B32F06A3114 priv aes-128 49539601EDF6D5FFE3EC226F6305BF256E54 localizedV2key
vlan 101
  vn-segment 900001
vlan 1000
  vn-segment 5000
vlan 1001
  vn-segment 5005
vrf context VXLAN
  vni 900001
  rd auto
interface Vlan1
interface Vlan101
  no shutdown
  vrf member VXLAN
  ip forward
interface Vlan1000
  no shutdown
  vrf member VXLAN
interface Vlan1001
  no shutdown
  vrf member VXLAN
interface nve1
  no shutdown
  member vni 5000
    suppress-arp
  member vni 5005
    suppress-arp
  no switchport
  vrf member VXLAN
  ip address 108.67.222.1/30
  no shutdown
  switchport access vlan 1001
  no switchport
  ip address 192.168.255.2/30
  no shutdown
interface mgmt0
interface loopback0
  ip address 2.2.2.2/32
icam monitor scale
line console
line vty
router ospf 150
  router-id 2.2.2.2
router bgp 65535
  router-id 2.2.2.2
  neighbor 1.1.1.1
    remote-as 65535
  vrf VXLAN
      network 192.168.11.0/24
    neighbor 108.67.222.2
      remote-as 65534
      local-as 65535
evpn
  vni 5000 l2
    rd auto
  vni 5005 l2
    rd auto
Hello
at first glance it looks like you have a two AS design, meaning your leaf as will see source/destination as the same thus negate route advertisement.
try:
router bgp 65535
allowas-in
vrf VXLAN
allowas-in
Kind Regards
Paul
Hi @paul driver ,
Just a small precision. allows-in would need to be applied to AS65534 (FWs) rather than to AS65535.
Hello @Harold Ritter
thanks for the clarification mate- tbh i only glanced over the topology as to which ASN was the “transit”  so i got it wrong.
@PingWhisperer  apologies
Kind Regards
Paul
Hi @PingWhisperer ,
I would suggest you remove the command "local-as 65535", as it is not required in this scenario and can sometimes cause issues when used in the improper scenario.
