WAE 515 Disk00 failure Error
I have a problem with a WAE 512. I think is a physical failure.
I don't know if I can some troubleshooting and may be i can solve the problem.
WAE512#show disks details
Disk drive not supported. (type 7 host 0 chan 0 id 1 lun 0)
Unsupported disk hardware.
Physical disk information:
disk00: Not used (*)
(*) Disk drive won't be used until replaced.
WAE512#sh alarms critical detail support
Critical Alarms:
Alarm ID Module/Submodule Instance
1 disk_failure sysmon disk00
Jan 29 07:07:32.475 EDT, Equipment Alarm, #000279, 1000:445000
Disk failure error occurred on disk00
/alm/crit/sysmon/diskXX/disk_failure:
A disk has failed.
Regards!
srimural
i too suspect u need to put an RMA for the same. coz the disk is not detected properly. if you can try entering the BIOS and check whether it is getting detected.
Srinath M
+91 99809 30364
