WakeOnLan (WOL ) through Cisco 870 not working
vic.orgos
I need to allow WOL packets through a Cisco 870W router to powerup pcs at a remote location. The device is running IOS version 12.4(9)T
The WOL magic packet will be coming from VLAN1 (192.168.2.0/24)  and going to FastEthernet4 (192.168.6.0/24).
The WOL application sends UDP packets on port 9
Here are the relevant running-config sections
interface Vlan1
ip address 192.168.2.30 255.255.255.0
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip route-cache flow
ip tcp adjust-mss 1452
interface FastEthernet4
ip address 192.168.6.1 255.255.255.0
** ip helper-address 192.168.2.1
** ip helper-address 192.168.2.10
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no cdp enable
** the iphelper addresses are the domain dhcp servers.
I've also found documents recommending I add
ip forward-protocol udp 9
which I've added and still nothing. Can anyone tell me why this is not working?
Thank you.
Vic.
paolo bevilacqua
Try setting a static ARP entry for the PC, on the router
It is not just one PC. I need to be able to wake up any workstation in the subnet on the other side of this router. Adding static arp entries is unmanageable.
Jon Marshall
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no cdp enable
Thank you.
Vic.
Vic
Add this to your config under the vlan 1 interface -
interface vlan 1
ip helper-address 192.168.6.255
Jon
vic.orgos
Solved it myself. I found that the PC that sends the magic packet,  which in our case is running RHEL (linux), needs a static route to the network in question. I then added
under FastEthernet 4, which is the interface for the network where the pcs are in.
Once I got that working, I locked it down a bit by creating an ACL
access-list 101 permit udp host 192.168.2.70 192.168.6.0 0.0.0.255 eq discard
and changed the first command to use the ACL like this
ip directed-broadcast 101
That is it. Thanks to all took the time to reply.
Vic.
