WAN Assessment
abbas.ali
I have a 10-Node MPLS Network with Cisco 2800/2600 routers.  I am currently not happy with the support that I am getting from the WAN provider.  The routers are running on outdate codes, they don't follow Cisco best practices and in order to convince the management I would to perform assessment on my own such as showing health check report to managment etc.  Is there any tool I could use to get the appropriate data such as over all health status, memory and CPU utilization etc.  I understand there are a few commands that I could use to get memory and cpu resoruces consumed by the routers etc, but for health check, I am looking for some freebie tools.
pompeychimes
Level 4
Level 4
Take a look at Solarwinds. They have 30 day trials for all of their software. The Engineers tool set is probably all you need.
James
