WAN bandwidth upgrade
Wassim Aouadi
Level 4
Level 4
I need to study the possibility of WAN bandwidth upgrade on our HQ.Do you have any suggestions as to how to analyze existing bandwidth usage, and if bandwidth upgrade is necessary? do you have any document/link you suggest to me?
thanks
Latchum Naidu
You need have a tool like NetFlow Analyzer to analyze the bandwidth.
This will analyze the bandwidth utilization on the link and give you in a graph like utilized up to 40% or 50% like that and also what all the source and destiantion address usage report per application wise.
You can download the trial version which valid for 30 days.
http://www.manageengine.com/products/netflow/download.html
Please rate the helpfull posts.
Naidu.
What about a document for WAN bandwidth design best practices/guide? Do you have some references?
thanks
There are few you can see from SolarWinds...
http://www.solarwinds.com/search/bandwidth-capacity-planning.aspx
And also there is a best pdf document from IBM about the Network performance and planning in wide area.
http://www-07.ibm.com/services/pdf/nametka.pdf
Naidu.
