wan by router
sakou1973
hello
i have got five switch connected by fiber and five router connecter by wimax
the routage will found it in the router
how to configure the router and how to implement the eigrp
thanks to give me the commande
Hello
your intentions are not clear can you please elaborate on your requirements?
res
Paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
paolo bevilacqua
As end user, without the necessary expereince and certification, the best approach would be that you hire a reputable consultant instead of trying of "finding the commands".
