WAN design using Cisco and Juniper SRX
Jigar Dave
Level 3
Level 3
Hello Experts,
I need your help, my current scenario is as follows
Local LAN is connected with cisco 2800 router and SRX 210 Firewall, currently all LAN segment will go to my Data Center via ISP A and all internet traffic from LAN segment will go to internet via SRX firewall, there is no relation/connection between cisco router and SRX firewall. I have separate AS no. s for both the ISP
Need your help, I am having attached scenario. based on current one I would like to do following.
1. I need to use PBR at LAN Switch ( its L3 Switch) such that in normal scenario - local VLAN traffic is equally distributed on both ISP.
2. dedicated internet traffic will flow through ISP B only and if WAN link of ISP B goes down, the internet traffic will pass through ISP A. ( in normal
scenario, ISP A will utilized 100 % for LAN traffic to reach it to DC but once ISP B link goes down, the b/w of ISP A will be divided to route 50% traffic for LAN segment to DC and rest 50% traffic of LAN segment to internet)
additionally, one question in my mind that I want to ask
is it possible to divide bandwidth of ISP B such that 70 % link will be utilized for internet traffic and 30 % link will be utilized for Local LAN subnet to reach to DC, what I understand that if ISP B is providing me services on SRX firewall then my all LAN traffic will advertise into MPLS cloud only then how that traffic will reach to internet.
please clarify
Thanks in advance
Jigar
rashidsiddiqui
For
point one you can use a PBR with even and odd IP segregation
access-list 100 permit ip 10.1.1.0 0.0.0.254 any
Route-map ABC permit 10
match ip address 100
set next hop ip
Apply the route-map on SVIs (Interface VLANs), using ip policy route-map.
Please rephrase your second question,
Hello Rashid,
Thanks for reply,
more clarification:-
--> I want ISP B dedicated to flow only internet traffic, if B goes down, internet traffic will pass through A ( at this time, 50 % b/w of A is used in internet traffic and rest 50% is used for internal LAN segment to reach to DC).
question of your PBR solution: I know PBR is one of the soluttion, can you give me how PBR is used between cisco and non-cisco device ( because here in my scenario, cisco and SRX both exists)
Thanks in advance
Jigar
