Connecting 2 switches to a Router
CSCO10675262_2
I have a router and 2 switches and I was wondering if it may be recommended to connect each switch to the same router for redundancy? An example of the network would be:
                                   ----------------Router----------------
                                   | (OSPF cost 1)                      | (OSPF cost 10)
                             switch A -------hsrp-------------Switch B
There would be different cost on the link from switch A and switch B to the router to setup the redundancy/preferred path, however not too sure if it may be a best practice/recommended?
An alternative I do know that is not recommended would be to setup bridging on the router and let spanning tree take care of the redundancy.
Thanks.
5 Replies 5
spremkumar
Level 9
Level 9
Due you have any specific requirement in terminating the L2 domain onto the switches? if possible you can terminated the same onto the router and make sure you run HSRP on those SVI interfaces rather than doing by what you have specified in your post.
regds
Jon Marshall
Thanks.
Depends on exactly what you are trying to do.
If the HSRP shown between the switches is actually HSRP running between the 2 interfaces on the router then this won't work as you can't assign 2 ethernet interfaces on the router from the same IP subnet.
However from the looks of your diagram it seems OSPF is running between the router and switches so can we assume the switches are L3 ?
If so then i would simply connect the switches to the router using L3 P2P links.If you do this then why prefer one path over the other ? It would be easier simply to use both paths. So config would look something like -
switch A
int gi0/1 <-- connects to router
no switchport
ip address 192.168.5.1 255.255.255.252
router ospf
network 192.168.5.0 0.0.0.3 area
switch B
no switchport
ip address 192.168.5.5 255.255.255.252
router ospf
network 192.168.5.4 0.0.0.3 area
router
int gi0/1 <--- to switch A
ip address 192.168.5.2 255.255.255.252
int gi0/2 <-- to switch B
ip address 192.168.5.6 255.255.255.252
router ospf
network 192.168.5.0 0.0.0.7 area
If the switches are L2 then you are going to have run BVI between the 2 router interfaces. Note if you do this STP will block one of the links for you anyway.
Jon
Thanks for the update. The reason on the preference of the ospf cost is due to security devices(example ips/etc...) connected between switch a and the router while switch b does not have a security device in between.
Not too sure if it would be recommended to have both the links from the router to the switches in the same ospf area 0 for faster convergence or to have them in different areas? The router is used for connection between offices (dwdm) as well as internet access.
Leo Laohoo
Just want to make sure your router has two ethernet ports to connect to both switches.
The router has several sfp gigabit ports (more than 10); thus this is definite not a problem.
