Time-Based Access Lists Using Time Ranges
Arup Dutta
Hi Expert ,
               I have one 2621 router i want to creat time base access list so that one of my subnet user(10.128.194.0 255.255.255.128) use only internet between 11am to 2pm.
please give me your expensive knowladge so i can configure it.
Arup
Can you try this
time-range NO_INTERNET
periodic daily 11:00 to 13:00
no access-list 7
ip access-list extended NAT
  deny ip 10.128.194.0 0.0.0.127 any time-range NO_INTERNET
  permit ip host 10.128.193.79 any
  permit ip host 10.128.192.219 any
  permit ip host 10.128.192.238 any
  permit ip host 10.128.192.253 any
  permit ip host 10.128.192.244 any
  permit ip 10.128.193.192 0.0.0.63 any
  permit ip 10.128.192.0 0.0.0.127 any
  permit ip 10.128.194.0 0.0.0.127 any
  exit
route-map NAT
match ip address NAT
exit
no ip nat inside source list 7 interface GigabitEthernet0/0
ip nat inside source route-map NAT interface Gig0/0
Regards.
Alain.
15 Replies 15
mrdogantr
The following example uses a time-range to deny HTTP traffic on Monday through Friday between the hours of 8:00 am and 6:00 pm:
time-range no-http
 periodic weekdays 8:00 to 18:00
access-list 101 deny tcp 10.128.194.0 0.0.0.127 any eq http time-range no-http
interface ethernet 0
 ip access-group 101 in
for more information;
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/timerang.html
hth
Muammer
Hi ,
Thank you for your quick reply but i want permit HTTP trafic between
11am to 1.30 pm for this perticulat subnet 10.128.194.0 0.0.0.127 .
please help me.
Arup
On Wed, Jan 5, 2011 at 5:33 PM, mrdogantr <
Hi ,
My router LAN ip is 10.128.195.253 0.0.0.3
I want to block HTTP VLAN network 10.128.194.0 0.0.0.127 (Using time base
access list)
please help me.
Arup
Permit or block??
And what about other traffic?
Regards.
Alain.
Hope you are doing well.
Actually i have 14 VLAN configure on 3750E-12s and one router cisco 2621.I
want all user of VLAN 7(10.128.194.0 255.255.255.128) access internet
between 11am to 1pm everyday but other VLAN user access internet all time.
This is my requirement
please share your valuable knowledge.
Arup
On Thu, Jan 6, 2011 at 1:12 PM, cadetalain <
I'm doing fine Thanks, hope you do too.
Are you doing NAT overload on the 2621?
Regards.
Alain.
Hi ,
i have overlod into my router
On Thu, Jan 6, 2011 at 2:37 PM, cadetalain <
ok so post your NAT config- along with corresponding ACl/route-map and I'll give you modified config so this vlan is not natted when doing http
connections.
Regards.
Alain.
please find the attachment file.
Arup
On Thu, Jan 6, 2011 at 2:59 PM, cadetalain <
Can you try this
no access-list 7
  exit
route-map NAT
exit
Regards.
Alain.
Hi ,
Thank you for your valuable advice and this application is working .But
i am facing a problem when i delete Time-range then my network is abale to
ping internet(when time-range is not match internet access condition ) and
user can't access internet between the schedule time that i assign into the
time range.
could you tell me please the step one by after when i assign this
1.time-range
2.Access-list
3.NAT
Arup
On Thu, Jan 6, 2011 at 4:15 PM, cadetalain <
It was not so valuable as that I just labbed with the config I gave you and here are the results:
when time-range not matched so you are outside of the hours then first ACE is not matched in ACL and the only match is the implicit deny at the end
but if you enter just after the first ACE: permit ip any  then it works outside time-range: it can go outside and in time-range it can't.
Regards.
Alain.
Hi Alien,
Thanks a lot for your support.
periodic daily 00:00 to 10:58
periodic daily 13:00 to 23:58
This time period is configure into my router according to my router
time(router time is exact with IST ).* periodic daily 00:00 to 10:58* after
this time period i am able to access internet after 15 to 17 minute when i
should access internet from 10.59 am.
Please tell me why happen like this !
Arup
On Fri, Jan 7, 2011 at 3:00 PM, cadetalain <
could you clarify please,post config and tell problem.
you should maybe add keyword log to the ACEs concerning your subnet and to an explicit deny at the end.
clear your nat, your ACl counters and then do some ping and post logs along with sh ip nat trans
Regards.
Alain.
