Wan Failover With IP SLA but The NAT don't follow the Acive Interface. ( To access Internet Manual command need to be typed )
plussier1
Hi, I setup a WAN Failover with IP SLA, this part is Working but I can't access Internet when the Internet switch from WAN-1 to WAN-2.
I Use a CISCO Model C881G+7-A-K9 SN#FTX18428274.
The prymary WAN is FE4 and the backup is the Integrated 3G Dialer-1.
If I want to access Internet after the internet access switch from WAN-1 to WAN-2 I need to Type this command
no ip nat inside source list 100 interface FastEthernet4 overload
If the Internet access switch Back to WAN-1 I need to type this command again to be able to access Internet
no ip nat inside source list 105 interface Dialer1 overload
Please see a part of my Config. I have DMVPN Tunnel too and IP SEC Tunnel. ( See the attached file for the Complete config. )
Here is a part of my Configuration
WAN-1 Interface FE4
description WAN-1 Main
ip address dhcp
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
crypto map Netgear
WAN-2 Dialer-1
interface Dialer1
ip address negotiated
ip nat outside
encapsulation slip
dialer pool 1
dialer idle-timeout 0
dialer string hspa-R7
dialer persistent
dialer-group 1
crypto map Netgear
IP SLA
ip sla auto discovery
ip sla 1
icmp-echo 70.80.188.1 source-interface FastEthernet4
timeout 6000
frequency 10
ip sla schedule 1 life forever start-time now
IP Route
ip route 0.0.0.0 0.0.0.0 70.80.188.1 track 10
ip route 0.0.0.0 0.0.0.0 Dialer1 5
NAT
access-list 100 deny ip 192.168.254.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 100 deny ip 192.168.254.0 0.0.0.255 192.168.52.0 0.0.0.255
access-list 100 deny ip 192.168.254.0 0.0.0.255 192.168.60.0 0.0.0.255
access-list 100 deny ip 192.168.254.0 0.0.0.255 192.168.116.0 0.0.0.255
access-list 100 permit ip 192.168.254.0 0.0.0.255 any
access-list 105 deny ip 192.168.254.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 105 deny ip 192.168.254.0 0.0.0.255 192.168.52.0 0.0.0.255
access-list 105 deny ip 192.168.254.0 0.0.0.255 192.168.60.0 0.0.0.255
access-list 105 deny ip 192.168.254.0 0.0.0.255 192.168.116.0 0.0.0.255
access-list 105 permit ip 192.168.254.0 0.0.0.255 any
Let me Know.
Thank you !
Patrick Lussier
2 Accepted Solutions
Philip D'Ath
You need to use route-maps.  Something like this.
Delete:
no access-list 100
Add:
ip nat inside source route-map NAT-FIXED interface FastEthernet4 overload
ip nat inside source route-map NAT-CELLULAR interface Dialer1 overload
route-map NAT-FIXED permit 10
match ip address 105
match interface FastEthernet4
route-map NAT-CELLULAR permit 10
match interface Dialer1
You didn't show me that config ... so I couldn't account for it.
I don't believe the issue is related to the route maps.  First you need to enable a keepalive mechanism to clear broken VPNs.  This needs to be done on both ends.
crypto isakmp keepalive 30
Next, is the remote end capable of handling you coming in from a different IP address?
Next DMVPN.  Do the tunnels both have the same destination, or different destinations?
8 Replies 8
Philip D'Ath
Delete:
no access-list 100
Add:
Hi Philip,
I tried that and now i keep Internet on my Laptop even if I switch from WAN-1 ISP to WAN-2 ISP, I still have access to Internet even if the internet access come from WAN-1 or WAN-2. but,
Unfortunately, Now with this new setting My Site-ToSite VPN Tunnel doesn't work even if the primary ISP is WAN-1 or the Backup WAN-2.
Same thing for my DMVPN (EIGRP) Tunnel, they stop working.
Do i need to add more information on Route Map ?
Let me know.
Thank You !
Hi Philip,
You can see on my first post the attached cisco881g.docx. all my router config is there i just remouve some Ip address.
1) Next, is the remote end capable of handling you coming in from a different IP address? YES
I have for the moment 4 Site-To-Site IP SEC VPN
2) Next DMVPN.  Do the tunnels both have the same destination, or different destinations?
In fact i have 4 DMVPN tunnel with 2 HUB and for to moment only 2 active Spoke but on a near future i will have around 20 Spokes.
The DMVPN tunnel are
Spoke-1 (WAN-1) to Hub-1 (WAN-1) 172.20.1.0 /24
Spoke-1 (WAN-1) to Hub-1 (WAN-2) 172.21.1.0 /24
Spoke-1 (WAN-2 to Hub-1 (Wan-1) 172.22.1.0 /24
Spoke-1 (Wan-2 to hub-1 (Wan-2) 172.23.1.0 /24
See the Tunnel Information bellow or the complete Router config on the First Post attached
cisco881g.docx
interface Tunnel0
description WAN-1-DM-1
bandwidth 1000
ip address 172.20.1.5 255.255.255.0
no ip redirects
ip mtu 1400
no ip next-hop-self eigrp 444
no ip split-horizon eigrp 444
ip pim nbma-mode
ip pim sparse-mode
ip nhrp authentication DMVPN_NW
ip nhrp map 172.20.1.1 xxx.xxx.xxx.xxx (HUB-1)
ip nhrp map multicast xxx.xxx.xxx.xxx
ip nhrp map multicast $$$.$$$.$$.$$$ (HUB-2)
ip nhrp map 172.20.1.2 $$$.$$$.$$.$$$
ip nhrp network-id xxxx
ip nhrp holdtime 60
ip nhrp nhs 172.20.1.1
ip nhrp nhs 172.20.1.2
ip tcp adjust-mss 1360
delay 100
tunnel source FastEthernet4
tunnel mode gre multipoint
tunnel key xxxxxx
interface Tunnel3
description DM-3_WAN-2
bandwidth 500
ip address 172.22.1.5 255.255.255.0
no ip redirects
ip mtu 1400
ip pim nbma-mode
ip pim sparse-mode
ip nhrp map 172.22.1.1 xxx.xxx.xxx.xxx (HUB-1)
ip nhrp map 172.22.1.2 $$$.$$$.$$.$$$ (HUB-2)
ip nhrp holdtime 60
ip nhrp nhs 172.22.1.1
ip nhrp nhs 172.22.1.2
delay 200
tunnel source Dialer1
tunnel key xxxx
interface Tunnel4
description WAN-2-DM-2
bandwidth 500
ip address 172.21.1.5 255.255.255.0
no ip redirects
ip mtu 1400
ip pim nbma-mode
ip pim sparse-mode
ip nhrp map multicast !!!.!!!.!!!.!!!
ip nhrp map 172.21.1.1 !!!.!!!.!!!.!!! (HUB-1)
ip nhrp map 172.21.1.2 **.*.**.*** (HUB-2)
ip nhrp map multicast **.*.**.***
ip nhrp holdtime 60
ip nhrp nhs 172.21.1.1
ip nhrp nhs 172.21.1.2
delay 250
tunnel key xxxxxx
interface Tunnel5
description DM-4_WAN-2
bandwidth 1000
ip address 172.23.1.5 255.255.255.0
no ip redirects
ip mtu 1400
ip pim nbma-mode
ip pim sparse-mode
ip nhrp map 172.23.1.1 !!!.!!!.!!!.!!! (HUB-1)
ip nhrp map 172.23.1.2 **.*.**.*** (HUB-2)
ip nhrp holdtime 60
ip nhrp nhs 172.23.1.1
ip nhrp nhs 172.23.1.2
delay 150
tunnel key xxx
Thank You again !
Patrick
If the hubs have two different public IP addresses, hard codes the routes to only go via one circuit.  For example:
ip route a.b.c.d 255.255.255.255 70.80.188.1 permannent
ip route e.f.g.h 255.255.255.255 Dialer1 permanent
Hi Philip,
I reboot the router and retry what you send me first and now it's working OK.
I don't know what is append the first time when I test It. Probably i forgot to erase something.
Other quick Question, how can i do port fowarding with my config ?
exemple external port 1024 fowarded to ip 192.168.254.100 internal port 8080
Is the fowarded port will work on both WAN-1 and WAN-2 ?
Thank You again !
Delete:
no access-list 100
Add:
This is become a bit of a complex config!
The port forward will not work on both interfaces at a time.  It will only work on the "active" interface that the default route is pointing via.
Basically you need something like:
ip nat inside source static tcp 192.168.254.100 8080 interface FastEthernet4 8080
ip nat inside source static tcp 192.168.254.100 8080 interface Dialer1 8080
Thank You for your time.
