WAN - Hssi-B-Port high errors
tedreese
Should the invent txclock command help eliminate some of the high errors seen on these Hssi point to point connections? I'm looking for a solution that will eliminate these high errors seen. Of course the provider always says no trouble found. The core router is a 7204VXR (NPR400). The config looks like this:
interface Hssi3/0
service-policy output PTC-TO-HAN-P2P-POLICY
load-interval 30
serial restart-delay 0
Then the other side is a cisco 3845 with the same type of module:
Mx HSSI-B Port adapter, 1 port. Config looks like this:
interface Hssi2/0
load-interval 30
service-policy output HAN-P2P-POLICY
4896 input errors, 4783 CRC, 0 frame, 96 overrun, 0 ignored, 17 abort
5 Replies 5
paolo bevilacqua
How many input packets ?
this is one 7204VXR side:
MTU 4470 bytes, BW 45045 Kbit, DLY 200 usec,
reliability 255/255, txload 83/255, rxload 19/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 01:21:46
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 91
Queueing strategy: weighted fair
Output queue: 0/1000/64/91 (size/max total/threshold/drops)
Conversations 0/179/256 (active/max active/max total)
Reserved Conversations 1/1 (allocated/max allocated)
Available Bandwidth 18018 kilobits/sec
30 second input rate 3526000 bits/sec, 2147 packets/sec
30 second output rate 14702000 bits/sec, 2564 packets/sec
9858536 packets input, 2323315924 bytes, 0 no buffer
Received 573 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
11329375 packets output, 3422481842 bytes, 0 underruns
0 output errors, 0 applique, 0 interface resets
0 carrier transitions LC=down CA=up TM=down LB=down TA=up LA=down
This is the 3845 side:
reliability 255/255, txload 24/255, rxload 77/255
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 1w1d
Queueing strategy: Class-based queueing
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/73/256 (active/max active/max total)
30 second input rate 13760000 bits/sec, 2422 packets/sec
30 second output rate 4416000 bits/sec, 2165 packets/sec
514107407 packets input, 2894366978 bytes, 0 no buffer
Received 89136 broadcasts, 0 runts, 0 giants, 0 throttles
0 parity
4923 input errors, 4809 CRC, 0 frame, 97 overrun, 0 ignored, 17 abort
521028387 packets output, 521951278 bytes, 0 underruns
Hi, you are fine. Cannot use the byet counter because it has rolled over, but
514107407 * 800 B/pft * 8 =
Excuse the garbage in other answer. Seems like you have a BER better that 1/10^8. Usually circuits are deemed acceptable in that area.
514107407 * 800 B/pkt * 8 bits in byte / 4923 =
668350072
Ok, my question is would the invent txclock config assist in clearing up these errors?
Ted
