WAN inaccesible through serial frame relay
paulpagecisco
I have just replaced a 2500 with a 2801 router, added wic serial module and it is connected) and 9 port ethernet switch (8 pc's static addressed connected to 9 port switch), I have entered the same config as I had on the 2500 with the exception of "router igrp 2". I cannot get to internet through any of the pc's connected. I know enough to know I know nothing. Should I be bridging the 9 port switch, instead of int fa 0/0? Do i need to enable EIGRP? I have included the config below. If anyone has any ideas as to why I cannot get to internet or even ping the router please help. Any information is greatly appreciated. The subinterface s0/2/0.1 is PPP to another remote site and I am just not sure if the bridge-grouping is right. Let me know if I should include remote config.
!version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime
service timestamps log datetime
service password-encryption
service udp-small-servers
service tcp-small-servers
service sequence-numbers
hostname option_care_clksbrg
boot-start-marker
boot system flash:c2801-entbasek9-mz.124-16b.bin
boot-end-marker
logging buffered 51200 debugging
logging console critical
no aaa new-model
clock timezone PCTime -5
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip domain name comprecare.local
ip host main 172.16.254.1
ip name-server 192.0.0.4
ip name-server 69.43.55.2
ip ddns update method sdm_ddns1
DDNS both
ipx routing 00e0.b055.c109
ip tcp synwait-time 10
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$$ES_LAN$$FW_INSIDE$
ip address 192.0.2.254 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
ipx network 20
no mop enabled
bridge-group 1
interface FastEthernet0/1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1/0
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
interface FastEthernet0/1/4
interface FastEthernet0/1/5
interface FastEthernet0/1/6
interface FastEthernet0/1/7
interface FastEthernet0/1/8
interface Serial0/2/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation frame-relay
ip route-cache flow
frame-relay lmi-type ansi
interface Serial0/2/0.1 point-to-point
ip address 172.16.2.1 255.255.255.0
ipx network 1620
no cdp enable
frame-relay interface-dlci 100 CISCO
bridge-group 1
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
no ip classless
ip route 0.0.0.0 0.0.0.0 172.16.2.2
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
logging trap debugging
snmp-server community public RO
no cdp run
control-plane
bridge 1 protocol dec
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
scheduler allocate 20000 1000
end
17 Replies 17
Paul
How about posting the current version of the config?
While bridging may be been the way to do things on the 2500 I am not at all certain that it works as you hope on the new router.
Rick
Rick
Hey Rick, here is the current config. On another note, did you notice the CISCO listed after the frame-relay dlci 100 on sub-serial. I had ansi selected, not sure why the CISCO shows up. Anyways, here is the Current configuration : 3047 bytes
! Last configuration change at 00:08:44 EST Thu Apr 17 2008
! NVRAM config last updated at 23:58:55 EST Wed Apr 16 2008
version 12.4
no service pad
boot-start-marker
boot-end-marker
enable secret xxx.
no aaa new-model
clock timezone EST -5
no ip source-route
ip cef
no ip bootp server
ipx routing 001e.bebd.8eb2
username BANI-WV privilege 15 secret xxx
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
no mop enabled
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ipx network 1620
no cdp enable
bridge-group 1
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
ipx network 20
bridge-group 1
router eigrp 2
passive-interface FastEthernet0/0
passive-interface FastEthernet0/1
passive-interface Serial0/2/0
passive-interface Serial0/2/0.1
passive-interface Vlan1
network 172.16.0.0
network 192.0.2.0
auto-summary
no ip classless
ip http server
no cdp run
control-plane
line con 0
login local
line aux 0
password xxx
login
line vty 0 4
privilege level 15
password xxx
login
transport input telnet
transport output telnet
line vty 5 15
privilege level 15
login local
end
Paul
I saw the config posted in another thread and responded with several comments and suggestions. So see that response. In that response I did comment on the ansi or cisco for the Frame Relay. I do note that in one of the posts in this thread you say that you were able to ping other routers in the network. If the ansi or cisco was configured at that point and you were able to ping other routers it shows that the Frame Relay was providing connectivity.
Rick
Rick
