DSL error: ATM0/2/0 is initializing, line protocol is down
HI all,
We have a DSL circuit coming into a 2821 with WIC1-ADSL card. The service is in Los Angeles' AT&T territory (Alcatel DSLAM) and provisioned as an RFC 1483 bridge with static IPs.  Encapsulation is aal5snap and the pvc is 0/35. How can I get the ATM to sync and bring the interface up and up?
Symptom:
sh int atm0/2/0
Anatomy:
*show version*
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(24)T6, RELEASE SOFTWARE (fc2)
*sh run int atm0/2/0*
interface ATM0/2/0
no ip address
no atm restart timer
no atm ilmi-keepalive
pvc 0/35
  no ilmi manage
  encapsulation aal5snap
*show diag*
WIC Slot 2:
DSL SAR (ADSL)
Hardware Revision        : 2.3
Part Number              : 73-4771-08
Board Revision           : A0
Deviation Number         : 0-0
Fab Version              : 05
PCB Serial Number        : FOC072526CQ
RMA Test History         : 00
RMA Number               : 0-0-0-0
RMA History              : 00
Product (FRU) Number     : WIC-1ADSL=
EEPROM format version 4
Any ideas?
Thank you in advance
--Athonia
Hello Athonia,
What we are observing is expected. What happened is that some WIC-1ADSL boards were built using an incorrect part but it happened long time ago for WIC-1ADSL cards shipped directly from Cisco after 10/01/03 do not have this problem. There is indeed a field notice Cisco created on this issue. There is one way to identify the affected cards: The part number will be 73-4771-08
Check the "show diag" you sent:
WIC Slot 2:
DSL SAR (ADSL)
Board Revision           : A0
Fab Version              : 05
RMA History              : 00
Thus, it is recommended to replace the card.
This will solve the issue!
Regards.
5 Replies 5
Jose Bogantes
Hello Athonia,
Please confirm the dsl operating-mode you are supposed to use. You can try using dsl operating-mode auto under the interface atm to know if that makes any difference. Please gather the following output to know if a firmware upgrade is needed:
show dsl interface atm 0/2/0
Thanks for your quick response. The 'dsl operating-mode' was definitely set to 'auto'. Here's the rest:
*show dsl interface atm 0/2/0*
ATM0/2/0
Alcatel 20150 chipset information
Line has not yet been activated.
Modem Status:           Down (DMTDSL_DLOAD_1)
DSL Mode:           Unknown
Interrupts:           0 (0 spurious)
PHY Access Err:           0
Activations:           0
LED Status:           OFF
LED On Time:           500
LED Off Time:           500
Init FW:           ASW_init_3_8_131.bin
Operation FW:           ASW_R3_8_131.bin
FW Source:           embedded
DSL: Training log buffer capability is not enabled
Hi Athonia,
Thanks for the information. Please gather these debugs:
  • Debug atm events
  • Debug atm errors
I also want to know if this was ever working or if you are trying a new setup. On the other hand, I would like to determine if you are getting ADSL or ADSL2+.
Regards.
Jose,
This is a new DSL setup and hadn't been working before. We tested it with a standard DSL modem when it was initially installed. The service we have is only standard ADSL (not ADSL2+ or anything like that)
*debug atm events & errors*
Sep 12 13:49:21.979 PDT: DSL(ATM0/2/0): No response from ASW_init_3_8_131.bin
Sep 12 13:49:21.979 PDT: DSL(ATM0/2/0): Unexpected response 0x0 to ASW_init_3_8_131.bin
Sep 12 13:49:21.979 PDT: DSL: SM: [DMTDSL_DLOAD_1 -> DMTDSL_INIT]
Sep 12 13:49:21.979 PDT: DSL: SM: [DMTDSL_INIT -> DMTDSL_DLOAD_1]
Sep 12 13:49:21.979 PDT: DSL(ATM0/2/0): Downloading ASW_init_3_8_131.binretry=0, reg=0xFF
retry=1, reg=0xFF
retry=2, reg=0xFF
Sep 12 13:49:22.003 PDT: DSL(ATM0/2/0): Could not send command 0x12 after 3 retries
Sep 12 13:49:22.003 PDT: DSL(ATM0/2/0): send command fails!!!
Sep 12 13:49:22.003 PDT: DSL(ATM0/2/0): Could not download ASW_init_3_8_131.bin
laxcavgw01#
Sep 12 13:49:34.503 PDT: DSL(ATM0/2/0): No response from ASW_init_3_8_131.bin
Sep 12 13:49:34.503 PDT: DSL(ATM0/2/0): Unexpected response 0x0 to ASW_init_3_8_131.bin
Sep 12 13:49:34.503 PDT: DSL: SM: [DMTDSL_DLOAD_1 -> DMTDSL_INIT]
Sep 12 13:49:34.503 PDT: DSL: SM: [DMTDSL_INIT -> DMTDSL_DLOAD_1]
Sep 12 13:49:34.503 PDT: DSL(ATM0/2/0): Downloading ASW_init_3_8_131.binretry=0, reg=0xFF
retry=1, reg=0xFF
retry=2, reg=0xFF
Sep 12 13:49:34.527 PDT: DSL(ATM0/2/0): Could not send command 0x12 after 3 retries
Sep 12 13:49:34.527 PDT: DSL(ATM0/2/0): send command fails!!!
Sep 12 13:49:34.527 PDT: DSL(ATM0/2/0): Could not download ASW_init_3_8_131.bin
laxcavgw01#
Sep 12 13:49:37.027 PDT: DSL(ATM0/2/0): Received 1 timer events during wait
laxcavgw01#
Sep 12 13:49:39.527 PDT: DSL(ATM0/2/0): Received 2 timer events during wait
laxcavgw01#
Sep 12 13:49:42.027 PDT: DSL(ATM0/2/0): Received 3 timer events during wait
laxcavgw01#
Sep 12 13:49:44.527 PDT: DSL(ATM0/2/0): Received 4 timer events during wait
laxcavgw01#
Sep 12 13:49:47.027 PDT: DSL(ATM0/2/0): No response from ASW_init_3_8_131.bin
Sep 12 13:49:47.027 PDT: DSL(ATM0/2/0): Unexpected response 0x0 to ASW_init_3_8_131.bin
Sep 12 13:49:47.027 PDT: DSL: SM: [DMTDSL_DLOAD_1 -> DMTDSL_INIT]
Sep 12 13:49:47.027 PDT: DSL: SM: [DMTDSL_INIT -> DMTDSL_DLOAD_1]
Sep 12 13:49:47.027 PDT: DSL(ATM0/2/0): Downloading ASW_init_3_8_131.binretry=0, reg=0xFF
retry=1, reg=0xFF
retry=2, reg=0xFF
Sep 12 13:49:47.051 PDT: DSL(ATM0/2/0): Could not send command 0x12 after 3 retries
Sep 12 13:49:47.051 PDT: DSL(ATM0/2/0): send command fails!!!
Sep 12 13:49:47.051 PDT: DSL(ATM0/2/0): Could not download ASW_init_3_8_131.bin
laxcavgw01#
Hello Athonia,
WIC Slot 2:
DSL SAR (ADSL)
Board Revision           : A0
Fab Version              : 05
RMA History              : 00
Regards.
