WAN IP Not reachable
kumarmh91282
Hi All,
have a issue with WAN IP not reachable from Internet.
Topology Details:
Two ISPs connected to Single Cisco Router with Public IP configured respectively [ Refer attached diagram]
Default route to ISP1 with IP SLA tracker with Ad 1
Secondary Default route with 10 AD to ISP2 with IP SLA Tracker
NAT enabled on Both WAN interfaces
LAN- Single subnet.
ISP are configured to work as Active and Standby with failover
Issue:  We are not able to ping ISP2 WAN interface from outside Internet ( I'm guessing since the default route is towards ISP1)
           We are able to ping ISP1 public IP / and also no ACLs configured and able to reach WAN2 interface IP address
          from LAN.
Requirement: We have cloud monitoring system which will check ICMP of both the WAN IPs
Need your suggestion/Guidance
Thanks in advance.
Any suggestions
the most likely reason is that because of the IP SLA, there is no route. Post the output of:
show ip route
show run
Hello
if you cannot ping a public a address from public internet then it has nothing to do with your internal network!
Kind Regards
Paul
balaji.bandi
Contact ISP, they may have filters.
          from LAN.
This is nothing to do with default route, the default route only effective from user going from inside to outside.
from Internet to WAN IP, should able to ping, as suggested contact ISP and check.
BB
Thanks for the suggestion and reply... will revert check with ISP and update the final output here
