WAN Link Backup - static route with object tracking
PAUL CHEN
Does anyone know if the 3750 standard image supports object tracking ?
I have 2 floors in a building with each floor having a single WAN link out to a mpls cloud.
I planning to have a L3 link between the 2 core switches on the 2 different floors and use static routing backup with object tracking for WAN link redundancy. Dynamic routing is not allowed.
Has anyone tried this yet ?
Your help is much appreciated.
Paul
royalblues
Level 10
Level 10
Paul,
For object tracking you would require IP SLA support which seems to be there with only 3750 Metro series..
use the feature navigator for checking out supported features
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, rate if it does
Narayan
