Wan link fiber-net choose ospf broadcast or ospf pt-to-pt
acbennyma
Dear all,
there is a branch office which will be connected back to HQ office via a fiber-net link with ospf area 0 only.
I want to ask do what kinds of ospf connection I need to use ( use default broadcast type or use point to point type to establish the ospf neighbor)?
What things I need to concern? What is the advantage or dis-advantage between them?
regards,
benny
vmiller
Level 7
Level 7
Make it point to point unless there is a compelling reason not to. Make sure you set your router priorities so your branch router does not become the DR.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Would recommend p2p.
Either should work. P2p slightly more efficient in that since there will only be the two OSPF neighbors across the link, OSPF doesn't have to perform some of its broadcast media access processing, e.g. DR and BDR election.
