WAN Load Balancing
christopher_tan
Hello all,
I would like to get some solution on below.
1. I have a single router which connect to two different provider internet circuit (circuit A and circuit B)
2. WAN facing running BGP
3. LAN facing running eigrp
4. LAN have two public subnet (100.1.1.0/24 and 200.2.2.0/24)
5. The issue i facing is, all traffics seems to use only one circuit A for incoming/outgoing. Nothing on circuit B
Attach diagram and router configuration.
Please help suggest a way to load balance both circuits for two public subnets.
Thanks.
Christopher
28 Replies 28
Seb Rupik
Hi there,
Try the following
router bgp 64520
maximum-paths 2
Now running 'sh ip route bgp' should show two (equals cost) paths for the prefixes being advertisd by the 9498 AS .
cheers,
Seb.
added "maximum-paths 2", but traffics still on one link.
Check the output of show IP BGP "arbitrary route" to make sure you are receiving routes from both ISPs. As an example, show ip bgp 8.8.8.8. If you are receiving route from only one ISP,  contact them to solve the issue.
If you are receiving routes from both ISP, try to follow the comment of Seb.
Masoud
received route from both ISP.
(Circuit A) -- Origin IGP, localpref 100, valid, external
(Circuit B) -- Origin IGP, localpref 100, valid, external, best
Hello
"What source and destination should i use?"
Any scr ip within your site your on to any received bgp ip prefix
"received route from both ISP."
Apply the following
router bgp xx
maximum-paths 2
res
Paul
Kind Regards
Paul
add "maximum-paths 2" without removing?
no neighbor 10.1.1.2 route-map LAN1 out
no neighbor 20.1.1.2 route-map LAN2 out
You do not need to remove any command. Just add maximum-paths 2 under bgp section
Masoud
Hello
You can leave the route-maps in the BGP process, but they are negating each other, So hence why i mentioned removing them.
res
Paul
Kind Regards
Paul
Route from Curcuit B has been selected as a best route, so only that route sits inside the routing table.
Please share one  more time the output of
show ip bgp 8.8.8.8
show ip route 8.8.8.8
Do not omit any lines. Repalce with x if you think some parts of output are sensitive.
Hello
Your Prefix-list and RM contradict each other and you are applying local preference to both ebgp peers?
Are you trying to establish load balancing this way?
ip prefix-list LAN1 seq 5 permit 100.1.1.0/24 <------------------------Same as Lan 3
ip prefix-list LAN2 seq 5 permit 200.2.2.0/24 <------------------------Same as Lan 3
ip prefix-list LAN3 seq 5 permit 100.1.1.0/24
ip prefix-list LAN3 seq 10 permit 200.2.2.0/24
route-map PREPEND permit 10                <------------------------Not being used
 set as-path prepend 64520 64520 64520
router bgp xx
maximum-paths 2
Clear ip bgp * soft
sh ip bgp
Sh ip route
Per-destination load sharing  - Default
show ip cef exact-route (scr) (dst)
(scr)  -> (dst) => IP adj out of  GigabitEthernet0/1
Per-packet load sharing
interface GigabitEthernet0/1
ip load-sharing per-packet
interface GigabitEthernet0/2
(scr)  -> (dst) => IP adj out of  GigabitEthernet0/2
etc..
res
Paul
Kind Regards
Paul
Hi Paul,
Refer to below:
MANI .P
Christopher_tan
   I understand you have two ISP's & you public IP Pool 100.1.1.0/24 , 200.2.2.0/24.
ISP1 : 10.1.1.1 at your end &  10.1.1.2 at ISP end .
ISP2 : 10.1.1.1 at your end &  10.1.1.2 at ISP end .
Bandwidth load balancing :
Only IP Pool 100.1.1.0 /24 send all the traffic thru ISP1 & when ISP1 link down that traffic will move to ISP2 .
Only IP Pool 200.2.2.0/24  send all the traffic thru ISP2 & when ISP2 link down that traffic will move to ISP1 .
eg : 100.1.1.0/24 -----> ISP1 Primary and ISP2Secondary
        200.2.2.0/24 -----> ISP2 Primary and ISP1 Secondary
step : 1 to create the prefix list  or acl
step:2 to create the route map with weight (two different value  )
step : 3 apply the route map in Bgp ( Inbound )
Please let me know any supporting document or any assistance ....
You exactly correct on my requirement.
ISP2 : 20.1.1.1 at your end &  20.1.1.2 at ISP end .
will following commands works?
ip prefix-list LAN1 seq 10 permit 200.2.2.0/24
ip prefix-list LAN2 seq 10 permit 100.1.1.0/24
router bgp 64520
route-map LAN2 permit 10
 match ip address prefix-list LAN2
route-map LAN2 permit 30
 match ip address prefix-list LAN3
 set local-preference 25
route-map LAN1 permit 10
 match ip address prefix-list LAN1
route-map LAN1 permit 30
Please advice the correct way if above not correct.
Appreciate your time.
Thanks.
Hello
Just to confirm -
100.1.1.0/24
200.2.2.0/24
Are these your lan subnets or are these ebgp routes advertied to you?
res
Paul
Kind Regards
Paul
